查看: 532|回复: 0
“精英格调新典范” Kia K5贴地姿态玩个性AIRBFT气动避震改装的魅力
发表于 2021-3-24 14:57:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The new model of elite style" Kia K5 plays the charm of personalized airbft pneumatic shock absorption modification
K5由世界三大汽车设计大师之一彼得希瑞尔恢宏设计,其车名首字母“K”,撷用“KIA”与英文“Kinetic”(动力)的首字母,代表企业领先的造车理念和尖端科技。2011年3月10日,东风悦达起亚K5将载着“精英格调新典范”的尊贵品质辉耀上市。
K5 is designed by Peter shirrell, one of the world's three major automobile designers. Its initials are "K" and "Kia" and "kinetic", representing the company's leading car making concept and cutting-edge technology. On March 10, 2011, Dongfeng Yueda Kia K5 will be launched with the noble quality of "new model of elite style".
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
As the saying goes, one low covers all ugliness
In recent years, HF refitting has been popular all over the streets
Pneumatic shock absorption
It's also one night's transformation into the world's best seller
话说这是个什么东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐及电子控制系统等
它其实和空气减震的原理与常见减震器,螺旋弹簧+减震筒形式原理十分类似,只不过通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往,能提供更好的性能表现,嗯!就是这么自信!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air tank and electronic control system
In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance between the car body and the ground can be adjusted by changing the volume of the air chamber (up and down direction), and the soft and hard characteristics can be changed to a certain extent. In addition, the size of the air vent of the shock absorber can be changed by the motor, so as to adjust the damping force of the shock absorber, Can provide better performance, eh! So confident!
