查看: 607|回复: 0
起亚K5改装气动避震低趴姿态完美落地
发表于 2021-3-23 16:52:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
  起亚K5改装气动避震低趴姿态完美落地
Kia K5 modified pneumatic shock absorber landing perfectly in low prone posture
起亚K5是东风悦达起亚旗下的一款中高级轿车,高腰线、强张力的设计让K5更趋动感,体现出来一种朝气与活力,这一款重量级的车型即将在2011年3月份上市。此车外形变动很大,更加时尚前卫,整体风格偏于运动,相当具有竞争力。
Kia K5 is a medium and high-class car owned by Dongfeng Yueda Kia. The design of high waistline and strong tension makes the K5 more dynamic, reflecting a kind of vigor and vitality. This heavyweight model will be launched in March 2011. The appearance of this car has changed a lot. It is more fashionable and avant-garde. The overall style is sporty and competitive.
说到低姿态改装,最具代表性的肯定是气动避震悬挂,能升能降,在享受低趴美的同时不影响日常使用,可谓一举两得,今天就来介绍一下起亚K5改装AIRBFT气动避震的案例,低趴效果完美展现!
When it comes to low-profile modification, the most representative one is definitely the pneumatic shock absorber suspension, which can rise and fall. It can kill two birds with one stone while enjoying the beauty of low lying. Today, let's introduce the case of Kia K5 modified airbft pneumatic shock absorber, which shows the perfect effect of low lying!
安装气动避震大致分为4个板块,也就是气动避震的安装,管路的铺设,线路的走位,和控制系统的安装!下面就来一步步的分解一下:
Installation of pneumatic shock absorber is roughly divided into four parts, that is, the installation of pneumatic shock absorber, pipeline laying, line positioning, and control system installation!Let's break it down step by step
First of all, the installation of pneumatic shock absorbers. The installation of pneumatic shock absorbers is actually the same as the replacement of ordinary twisted tooth shock absorbers. Shock absorbers are all the installation positions of the original vehicle. What we need to pay attention to is to calculate the maximum and minimum range required by the owner according to the shock absorbers' journey, so as to adjust the height of the throttle shock absorbers. In addition, there is the reserved position of the air pipe, which is generally on the inside Yes, the rest is to follow the normal shock absorption installation steps.
Pipeline laying, pipeline laying is quite time-consuming work, each installation master's method and idea are different, but to follow a principle is to avoid the possible bending or vehicle driving may be pressed or ground to the gas pipe, and is far away from the exhaust, because the gas pipe material is prone to high temperature, the best way is It's going with the tubing.
It's very troublesome to move the lines along with the electrical circuits in the car. It's better not to cut off the main power line if you need to disassemble many interior parts. In addition, if there are other electrical equipment in the car, you must not share the power line to prevent mutual interference.
The installation of control system, airbft pneumatic shock absorption control system is quite simple control system, but want to perfect the installation or must have some experience, there are many details need to pay attention to, especially each joint and gas pipe and gas hole screw tooth connection, should be carefully installed, gas hole and joint screw tooth connection must be sealed, should be in case of leakage It's very troublesome to check and test the gas condition again. Try to do it in one step.
