查看: 453|回复: 0
高尔夫7代AIRBFT气动避震施工三段记忆版本双静音泵五加仑鱼雷罐
发表于 2021-3-23 16:41:49 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Golf 7 generation airbft pneumatic shock absorber construction three stage memory version double silent pump five gallon torpedo tank
大众高尔夫七改装气动避震 ,采用的是台湾的AIRBFT气动避震套件,前后独立升降,无线遥控,个性的后背箱灯光设计,完美打造高尔夫MK7的经典气动避震低姿态!
VW Golf 7 is refitted with pneumatic shock absorbers. It adopts Taiwan's airbft pneumatic shock absorbers. It can lift independently from front to back, wireless remote control, and personalized light design in the trunk. It perfectly creates the classic pneumatic shock absorbers low posture of golf Mk7!
Today's refitted riders begin to take their own unique route in order to show their own taste. Hellaflush modification is the most tasteful modification style at present.
They may have found that more and more cars are developing from "down" to "out". The appearance of more and more cars has an indescribable flavor. They seem to be unconventional and similar to VIP, but they are always somewhat similar in shape but not in spirit. Congratulations. Maybe these cars are all on the same route - Hella flush.
Let's break down the word hellaflush = hellaflush, which means there are two parts, one is Hella, the other is flush. Hella is the abbreviation of hell of, which means special, extraordinary, absolute and super; flush means flush. So here are two points to understand: 1. The formation of hellaflush must first meet the requirements of flush, that is, the flat wheel hub tire, and then be qualified to work hard from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
Nowadays, hellaflush has become an international appearance trend of refitted cars, more and more popular, more and more accepted by the public. Regardless of the type of cars, hellaflush has become a kind of taste certification. So, join the sport!
