查看: 558|回复: 0
进化延续经典丰田赛利卡改装气动避震颜值与内涵并存
发表于 2021-3-23 16:10:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Evolution and continuation of the classic Toyota sailika modified pneumatic shock absorber
赛利卡是和SUPRA、MR2并称为丰田跑车的当家花旦。这款当年在世界拉力锦标赛上有着非凡表现的小跑车,在国外的受欢迎程度绝对不输给它的同门师兄SUPRA。
Sailika, together with supra and MR2, is the leader of Toyota sports car. This year in the World Rally Championship has an extraordinary performance of the small sports car, in foreign countries, the popularity is absolutely not inferior to its classmate Sura.
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
As the saying goes, one low covers all ugliness
In recent years, HF refitting has been popular all over the streets
Pneumatic shock absorption
It's also one night's transformation into the world's best seller
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
So what is it?
It's actually a system that controls the air pressure
A device for changing the height of a car
Similar to the legendary ABC
But its working medium is gas
Generally speaking, it's just a set of things as shown in the figure below
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信!
Including elastic rubber airbag shock absorber
And electronic control system
It is actually the same as the principle of air shock absorber and common shock absorber
Coil spring + shock absorber
The principle is very similar
Just by changing the volume of the chamber (up and down)
To adjust the distance between the car body and the ground and change the soft and hard characteristics to a certain extent
In addition, the size of the air vent can be changed by the motor
Therefore, the air shock absorber is often used
Yeah! So confident!
