查看: 447|回复: 0
奔驰cla轿跑改装气动避震悬挂 简洁低趴路线走起
发表于 2021-3-23 14:58:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Benz CLA car refitted with pneumatic suspension, simple low lying route
奔驰CLA是奔驰首款基于紧凑级车身底盘开发的四门轿跑车,2013年北美车展上,奔驰正式发布了全新四门Coupe车型CLA。
该车基于MFA平台打造,外形设计非常动感。鉴于市场对于四门轿跑车型的需求热度,梅赛德斯-奔驰将自己流畅而优美的弧顶线继续向下延伸,一举推出全新的CLA进军年轻消费者的潜在市场。
Mercedes Benz CLA is the first four door coupe developed by Mercedes Benz based on compact chassis. At 2013 North American auto show, Mercedes Benz officially released its new four door coupe model cla.
The car is based on MFA platform, and its shape design is very dynamic. In view of the market demand for four door sedan cars, Mercedes Benz will continue to extend its smooth and beautiful arc top line downward, launch a new CLA at one stroke, and enter the potential market of young consumers.
奔驰CLA作为奔驰最小的一款轿跑车车型,外观设计时尚个性,改装走姿态路线一定是没错的,今天这台奔驰CLA改装气动避震低姿态分享给大家!
As the smallest coupe of Mercedes Benz, the appearance design of Mercedes Benz CLA is fashionable and personalized, and it must be right to refit it to take a posture route. Today, this Mercedes Benz CLA refitted with pneumatic shock absorbers will share with you!
AIRBFT专用气囊:
Airbft airbag:
