查看: 566|回复: 0
“千万荣放,与美好同行”本田CRVAIRBFT气动难以抗拒的低姿态魅力
发表于 2021-3-22 16:16:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Ten million glory, go with the beautiful" Honda crvairbft aerodynamic irresistible low profile Charm
本田CR-V是东风本田汽车公司生产的一款城市经典SUV车型,2015款CR-V主打运动时尚的设计外观,搭配米其林Latitude系列SUV轮胎,操控性能极佳。
CR-V(comfortable runabout-vehicle)秉承着“无论何时、无论何地、都能轻松、愉快驾驶”的开发理念,诞生25年来,揽获了160多个国家超过1100多万车主的喜爱。  2004年进入国内市场17年来,凭借自身的产品实力成功开拓了中国城市SUV市场,同时也收获了国内220万车主的支持与认可。
Honda CR-V is a city classic SUV produced by Dongfeng Honda Motor Company. The 2015 CR-V focuses on the design and appearance of sports fashion. With Michelin latitude series SUV tires, it has excellent handling performance.
CR-V (compatible runabout vehicle) adheres to the development concept of "easy and happy driving at any time and anywhere". Since its birth 25 years ago, CR-V has won the favor of more than 11 million car owners in more than 160 countries. In the past 17 years since entering the domestic market in 2004, with its own product strength, it has successfully developed China's urban SUV market, and also gained the support and recognition of 2.2 million domestic SUV owners.
有人说玩改装是为了装酷/撩妹,有人说玩改装是为了烧钱/追求刺激,每个人走进改装圈的理由并不相同。但大多数人都是浅尝辄止,从不深究背后的东西。就像改装圈里一直盛传着一句话,“百改降为先,一低遮百丑”,气动避震可以说是改装发烧友们最热衷的项目。可有多少人真正把它玩明白了呢?
Some people say that the purpose of refitting is to be cool / seductive. Others say that refitting is to burn money / pursue excitement. Everyone has different reasons to enter the refitting circle. But most people are superficial, never delve into the things behind. It's just like a popular saying in the refitting circle that "one hundred retrofits should be reduced first, one low should cover one hundred ugliness". Pneumatic shock absorbers can be said to be the favorite project of refitting enthusiasts. But how many people really understand it?
话说这是个什么东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器,螺旋弹簧+减震筒形式,原理十分类似,只不过通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往,能提供更好的性能表现,嗯!就是这么自信!
So what is it? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is the set of things shown in the figure below
They include elastic rubber air bag shock absorber, air pressure control system, trunk air tank and electronic control system. In fact, the principle of air shock absorber is very similar to that of common shock absorber, coil spring + shock absorber, except that the distance from the body to the ground can be adjusted by changing the volume of the air chamber (up and down direction) and the soft and hard characteristics can be changed to a certain extent. In addition, the shock absorber can be used to reduce the vibration In other words, the size of the air vent can be changed by the motor to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance, eh! So confident!
