查看: 515|回复: 0
“难以被复刻的经典” SKODA AIRBFT气动避震之低趴走起改装案例
发表于 2021-3-22 15:16:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Hard to be copied classic" Skoda airbft pneumatic shock absorber: low lying walking up modification case
斯柯达(SKODA),德国大众汽车公司经典品牌之一,总部位于捷克姆拉达-博莱斯拉夫,是世界上历史最悠久的四家汽车生产商之一。该品牌创立于1895年。
Skoda, one of the classic brands of Volkswagen, is headquartered in mlada Boleslav, Czech Republic. It is one of the four oldest automobile manufacturers in the world. The brand was founded in 1895.
SKODA气动避震升级空气避震悬挂采用的是AIRBFT空气避震系统,具有三段记忆和四轮独立功能,目前是世界上最顶级的避震系统,质量稳定,做工完美,低趴灵魂的缔造者,深受广大趴迷的痴爱。
Skoda pneumatic shock absorption upgrade air shock absorption suspension adopts airbft air shock absorption system, which has three sections of memory and four wheels of independent function. At present, it is the world's top shock absorption system with stable quality and perfect workmanship. It is the creator of low lying soul and deeply loved by fans.
The refitting of automobile chassis has a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now. Refitting is imperative. In recent years, the refitting of twisted tooth shock absorber is the mainstream choice of the players. It not only reduces the body, increases the aesthetic feeling, but also improves the vehicle control. However, the hardness is not acceptable to ordinary people. The rotten road makes the twisted tooth party miserable. Now it's very angry The emergence of dynamic shock absorbers makes the players who play with twisted teeth see a new dawn. The low lying effect when parking, and the car body can be raised when driving. It's really cool to lift at will. If the adjustment is good, the comfort is a little better than the tooth twisting. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
