查看: 557|回复: 0
本田思域三段记忆手机APP最华丽的气动避震,与时尚同行
发表于 2021-3-21 15:14:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda Civic's three segment memory mobile app is the most gorgeous pneumatic shock absorber, which goes with fashion
Honda Civic has launched a variety of models to cater to the tastes of consumers in different countries, including three door hatchback hatchback hatchback, coupe, hybrid and five door saloon. Honda Civic, which is listed in China, and Dongfeng Honda's existing model Honda CR-V come from the same production platform. The two cars use the same chassis, which provides a prerequisite for Honda Civic to be made in China. After 40 years of experience and continuous evolution in 10 generations of interpretation, today's 10th generation Civic (Civic) condenses many advanced technologies of the leading era, presenting you with a great sense of future and technology.
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏本田思域改装气动避震悬挂的魅力
Automobile refitting is a product of the automobile aftermarket. Because the original design of many models is mediocre and can not meet the requirements of the players, the refitting industry is booming. The refitting of pneumatic suspension is a kind of appearance refitting, which can arouse strong resonance with the ground beauty, the strong visual impact and the unconventional state of the players, Let's enjoy the charm of the modified pneumatic suspension of Honda Civic
首先,在更换车辆避震系统前一定要先知道更换的避震器的功能,以及你改装的需要。当然避震器的主要构成是由四个避震弹簧以及四只避震筒组合而形成,弹簧最主要的功用是用来消除行经不平路面的震动,我想这谁都知道。但许多人会问四只避震筒在车辆行进中又可以起到什么样的作用?其实避震筒的真正用途用来抑制弹簧吸震後反弹时的震荡和吸收路面冲击的能量。假如你开过避震器坏掉的车,你就可以体会车子通过每一坑洞、起伏後馀波荡漾的弹跳,而避震器正是用来抑制这样的弹跳。没有避震器将无法控制弹簧的反弹,车子遇到崎岖路面时将会产生严重的弹跳,过弯时也会因为弹簧上下的震荡而造成轮胎抓地力和循迹性的丧失,所以避震筒对车辆的操控力还是起着至关重要的作用。
First of all, be sure to know the function of the replaced shock absorber and the need of your modification before replacing the vehicle's shock absorber system. Of course, the main structure of the shock absorber is composed of four shock absorbers and four shock absorbers. The main function of the spring is to eliminate the vibration of the uneven road. I think everyone knows that. But many people will ask what role can four shock absorbers play when the vehicle is moving? In fact, the real purpose of the shock absorber is to suppress the shock when the spring rebounds after the shock absorption and absorb the energy of road impact. If you've ever driven a car with a broken shock absorber, you can experience the bouncing of the car through every hole and after the ups and downs, and the shock absorber is used to suppress such bouncing. Without the shock absorber, the rebound of the spring can not be controlled. When the car encounters a rough road, it will have a serious bounce. When it turns, it will also cause the loss of tire grip and tracking due to the vibration of the spring up and down. Therefore, the shock absorber still plays a vital role in the control of the vehicle.
