查看: 520|回复: 0
“打破传统 不断创新”保时捷987气动避震完美改装展示醉美姿态范儿!
发表于 2021-3-21 14:40:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Break the tradition and keep innovating" the perfect modification of the pneumatic shock absorber of the Porsche 987 shows its intoxicating posture!
本期给大家带来保时捷987改装案例,虽然经营保时捷升级的改装店很多,不过大多数都是升级原厂配置的,很难会见到改气动玩姿态的。因此本期案例中这辆987可以说是很难得的参考案例了。
This issue brings you the modification cases of the Porsche 987. Although there are many modification shops operating the upgrade of Porsche, most of them upgrade the original configuration, so it's hard to see the modification of pneumatic play posture. Therefore, this 987 is a rare reference case in this issue.
改装从来都没有哪些条条框框,是门讲究走心、讲究个性的艺术。只要你能想得到,便可通过双手逐一实现,去完成内心中最为完美的艺术品。但改装绝非一日之功,而是需要不断的完善,是一点一点的堆砌才能呈现出来的。
There are no rules and regulations in refitting. It's an art of paying attention to attention and individuality. As long as you can think of it, you can achieve it one by one with your hands to complete the most perfect artwork in your heart. But the modification is not a one-day effort, but needs continuous improvement, is a little bit of stacking to show.
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more people accept it. HF model has become a symbol of taste
Let's break down the word hellaflush = hellaflush, which means there are two parts, one is Hella, the other is flush. Hella is the abbreviation of hell of, which means special, extraordinary, absolute and super; flush means flush. So here are two things to be very clear about:
1. The formation of hellaflush must first satisfy the requirement of flush, that is, flat wheel hub tire, and then be qualified to work hard from flush to hellaflush;
2. The body height must be as low as possible. From the side of the car, there must be no gap between the tire and the leaf plate.
Nowadays, hellaflush has become an international appearance trend of refitted cars, more and more popular, more and more accepted by the public. Regardless of the type of cars, hellaflush has become a kind of taste certification. So, join the sport!
