查看: 513|回复: 0
宝马530AIRBFT气动避震完工呈现不同凡响的低趴姿态魅力
发表于 2021-3-21 14:09:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 530airbft pneumatic shock absorber completed, showing extraordinary low posture charm
宝马530是华晨宝马汽车有限公司推出的一款汽车,宝马530采用直6汽油发动机,四气门技术,双凸轮轴可变气门正时控制系统(Double-VANOS),数字式电子发动机管理系统(DME)技术。
BMW 530 is a car launched by BMW Brilliance Automobile Co., Ltd. BMW 530 adopts straight 6 gasoline engine, four valve technology, double VANOS and DME technology.
改装车与我们的生活联系越来越紧密。各种车型的改装案例在我们的生活中都能见到,一些经典老车或是新款的车型都有不同的群体玩家,今天我们就来看看最新款宝马530改装AIRBFT气动避震悬挂拥有怎么的姿态效果!
Refitting cars is more and more closely connected with our life. The refitting cases of various models can be seen in our life. Some classic old cars or new models have different groups of players. Today, let's take a look at the attitude effect of the latest BMW 530 refitting airbft pneumatic suspension!
