查看: 552|回复: 0
“ 一个旅行的梦想”Wolkswagen Passat 休旅车AIRBFT气动避震改装完美下架
发表于 2021-3-21 13:35:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"A dream of travel" walkswagen Passat
旅行车兼顾了轿车舒适性及SUV大空间的优势,是欧美市场消费者比较喜爱的车型。在今年3月举办的日内瓦车展期间,大众发布了新款帕萨特旅行版车型。近日大众新款帕萨特旅行版现身海外地区,该车将与奔驰C级旅行版、奥迪A4 allroad等车型一同丰富该细分市场,提供给消费者更多的购车选择。今天给大家分享的是 Wolkswagen Passat 休旅车气动避震改装低趴案例,一个旅行的改装梦!
The station wagon takes into account the advantages of car comfort and SUV large space. It is a popular model for consumers in European and American markets. During the Geneva Motor Show in March this year, Volkswagen launched the new Passat travel model. Recently, Volkswagen's new Passat travel version has appeared in overseas regions, which will enrich the market segment together with Mercedes Benz C-class travel version, Audi A4 allroad and other models, and provide consumers with more choices. Today, I'd like to share with you the case of the pneumatic shock absorber refitting of wolkswagen Passat, a dream of refitting in travel!
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
