查看: 506|回复: 0
李洋推荐AIRBFT双泵套件专用支架,购买套件免费赠送,安装简单,造型美观
发表于 2021-3-21 13:12:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Li Yang recommends the special bracket for airbft dual pump kit, which is free of charge when purchased, with simple installation and beautiful appearance
The installation of pneumatic shock absorber will link a control remote controller in the car. You can set several gears according to your own requirements. You can quickly switch between a variety of heights. In this way, you can make the car "lie down" on the ground when parking and rise to the normal driving height when driving normally.
