查看: 700|回复: 0
最美瓦罐 迈腾旅行版改装气动避震人生完美姿态
发表于 2020-12-22 16:02:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The most beautiful tile jar maiteng travel version refits the pneumatic shock absorber life perfect posture
迈腾四驱旅行版在2012年9月1日成都车展正式上市。本次上市的共有两款车型,具体为2.0TSI舒适版36.18万元,2.0TSI豪华版41.21万元。该车在迈腾旅行版的基础上增添了新的车身套件,配备大众4MOTION全轮驱动系统。
Maiteng four-wheel drive travel version was officially launched in Chengdu auto show on September 1, 2012. There are two models on the market, including 361800 yuan for the comfortable version of 2.0tsi and 412100 yuan for the luxury version of 2.0tsi. The car is based on the maiteng Travel Edition with a new body kit, equipped with VW 4MOTION all wheel drive system.
大众迈腾作为国内随处可见的B级车,一直以来都给人一种沉稳、低调的形象,奢华素雅,低调内涵。不得不说明迈腾是一台改装的好底子,今天我们为大家带来的就是一台素雅的低趴迈腾 , 其修长的车身姿态尽显完美的低趴范,最美诱惑,帅到没朋友。
As a B-class car that can be seen everywhere in China, Volkswagen maiteng has always given people a calm, low-key image, luxurious and elegant, low-key connotation. We have to say that maiteng is a good base for refitting. Today, we bring you a simple and elegant low lying maiteng, whose slender body posture shows perfect low lying fan, the most beautiful temptation, handsome to have no friends.
There are four advantages mentioned above. In fact, most of the riders want to lower themselves better The lower the car is, the better it is.
It is also a matter of great vanity to be able to enjoy the attention of people around.
