查看: 701|回复: 0
新款速腾改装AIRBFT气动避震 展现醉美低趴风格!
发表于 2020-12-21 16:09:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The new speeder refitted airbft pneumatic shock absorbers show the Drunken Beauty low lying style!
速腾(Sagitar),是一汽-大众旗下的合资A+级三厢轿车品牌,该车于2006年4月9日投入中国市场,其前身为德国大众汽车旗下第五代捷达(Jetta)轿车,定位为“德系高性能轿车”。
2006年4月9日,德国大众公司将紧凑型轿车第五代捷达引入中国市场,并将其更名为“速腾”。   2012年,速腾推出换代车型,于3月北京车展后正式上市,但该款车型之后出现了严重的底盘悬挂质量问题,部分车主汽车遭遇后轴纵臂断裂事件,该问题遭到了央视315晚会曝光以及大量车主的投诉。  2015年,一汽大众宣布召回问题车型,将后轴纵臂上安装金属衬板  2019年3月,一汽大众推出基于MQB-A1平台打造的换代车型速腾Long-Wheelbase,车型车身长度超过4.7米,轴距超过2.7米。
2020年11月,2021款速腾正式上市,该车型为年度改款,全系增加了车联网、8.0英寸彩色液晶仪表等功能。
Sagitar, a joint venture brand of a + class sedan under FAW-VW, was put into the Chinese market on April 9, 2006. Its predecessor was the fifth generation Jetta sedan of German Volkswagen, which was positioned as "German high-performance car".
On April 9, 2006, German Volkswagen introduced the fifth generation Jetta compact car into the Chinese market and renamed it "Suteng". In 2012, Suteng launched a new model, which was officially launched after the Beijing auto show in March. However, there were serious chassis suspension quality problems after this model. Some car owners suffered from the fracture of the rear axle longitudinal arm. This problem was exposed by CCTV 315 evening party and a large number of car owners complained. In 2015, FAW Volkswagen announced that it would recall the problem models and install metal lining plates on the rear axle longitudinal arms. In March 2019, FAW Volkswagen launched a new generation of speedeng long wheelbase based on the mqb-a1 platform, with a body length of more than 4.7 meters and a wheelbase of more than 2.7 meters.
In November 2020, 2021 model of Suteng was officially put into the market, which was changed annually. The whole series added functions such as Internet of vehicles, 8.0 inch color LCD Meter, etc.
它们不仅可以跑,而且跑的可以很精彩!
不然怎么能叫“贴地飞行”呢!
在路上经常会被那些改装过的车所吸引因为,他们真的很美
在改装车中有很多车主都给爱车改了悬挂,空气悬挂是最常见的至于为什么那么多人选择气压减震器,我想…是因为…
①外观太炫酷停在路边永远不缺乏关注度,走在路上回头率那是相当高啊
②自适应性,空气弹簧的弹性系数可以自动调节,当高速行驶时,悬挂可以变硬,以提高车身稳定性,低速行驶时,悬挂会变软来提高减震舒适性,在高速过弯时,空气弹簧和减震器会自动调节,外侧车轮的空气弹簧和减震器,会自动变硬,以减小车身的侧倾,提供更高的操控极限性以及舒适度,这也是好多SUV车型自带空气悬挂的原因
③装B利器,无论你是停在那里还是行驶中,可调节的车身高度可以适用各种装B场合当然,不光外观很装B,打开后备箱更是如此,因为空气悬挂装置放在备箱处,所以当你打开后备箱,露出炫酷的空气悬挂气罐那一刻时,那B装的绝对可以亮瞎他人那铝合金双眼
The low lying posture that can be seen everywhere in life also makes many laymen have doubts With the car so low, is it easy to run? Do you dare to run like this!
They can not only run, but also run very exciting!
On the road, I'm always attracted by the cars that have been refitted because they are really beautiful
In the refitted car, many car owners have changed their car suspension. Air suspension is the most common one. As for why so many people choose pneumatic shock absorber, I think Because
① The appearance is too cool. Parking on the side of the road will never lack of attention. When walking on the road, the rate of turning back is quite high
② When the vehicle body is in high speed, the air spring can be adjusted automatically to improve the flexibility of the suspension and the air spring can be adjusted automatically at high speed For higher handling limit and comfort, this is the reason why many SUV models have air suspension
③ No matter where you park or drive, the adjustable body height can be used in all kinds of B loading occasions. Of course, not only the appearance of B is very good, but also the opening of the trunk is more so. Because the air suspension device is placed in the spare box, when you open the trunk and expose the cool air suspension air tank, the b-mounted can absolutely blind other people's aluminum eyes
