查看: 696|回复: 0
锐志改装气动避震低姿态魅力开出百万豪车感觉!
发表于 2020-12-21 15:40:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Determined to refit pneumatic shock absorbers, low-profile charm, a million luxury car feeling!
锐志(REIZ)是日本丰田MARK X车型国产后的名称,它于2005年10月在天津一汽丰田二厂与皇冠共线生产、共用底盘,配备与皇冠相同的六速手自一体变速器。它于2017年9月停产,共计生产528188辆。
MARK X则是MARK II 的后续车型,它采用前置后驱设计,在丰田所有车型中销量排第三位,在定位上仅次于皇冠。TOYOTA丰田,全球第一大汽车集团的出品,原车型是在日本广受好评的“MARK-X”系列,整体的档次定位就在同厂著名车系-凯美瑞之上(REIZ锐志是高于CAMRY凯美瑞,而仅低于CROWN皇冠的第二重量级车型),说到大的方面有丰田先进、可靠、耐用的2500CCV缸、3000CCV缸引擎;有制作工艺精细且极为复杂的6前速自动换档变速器,包括前卫造型的手自一体蛇形换档面板系统;成本较高的后轮驱动系统,这是豪华车的配置,行驶会更加稳定;还有令人眩目的车头造型,有着雷克萨斯G,S系跑车的影子;后双排气管隐藏式暨后护杠一体化设计,真是龙头虎尾造型、强劲的心脏(引擎)、先进的变速、稳定的行走(后轮驱动)。
在日本MARK X是一款运动型车,而国产后,MARK X被赋予了一个响亮的中文名――锐志(Reiz),同时在德语中意为“魅力”的“Reiz”也出现在车的尾部。这款车的定位区间(功能的对手/非单纯价格)非常的大,从十几万上下的宝来,到Mazda6、天籁、奥迪A4直到宝马530i,只要和运动沾边的车,都可以看作它的对手。
Reiz is the name of Japanese Toyota mark X after it was made in China. In October 2005, Reiz was produced and shared chassis with crown in Tianjin FAW Toyota No.2 factory. It is equipped with the same six speed automatic manual transmission as crown. It stopped production in September 2017 with a total production of 528188 vehicles.
Mark X is the follow-up model of Mark II. It adopts the front and rear drive design. It ranks the third in the sales volume of all Toyota models, next only to crown in terms of positioning. Toyota is the product of the world's largest automobile group. The original model is the "mark-x" series, which is widely praised in Japan. The overall grade positioning is above Camry (Reiz is the second heavyweight car model higher than Camry Camry, but only lower than crown crown). In terms of big aspects, Toyota has advanced, reliable and durable 2500ccv cylinder and 3000ccv cylinder engine There are 6-speed automatic shift transmission with fine manufacturing process and extremely complex, including the avant-garde hand and self-contained serpentine shift panel system; the high-cost rear wheel drive system, which is a luxury car configuration, will be more stable; and the dazzling front shape, with Lexus G, The shadow of S series sports car; the hidden rear double exhaust pipe and integrated design of rear guard bar, which is really the dragon head and tail shape, strong heart (engine), advanced speed change and stable walking (rear wheel drive).
In Japan, mark X is a sports car. After being made in China, mark X has been given a resounding Chinese name - Reiz. At the same time, Reiz, which means "charm" in German, also appears at the rear of the car. The positioning range of this car is very large, from Bora, Mazda6, Teana, Audi A4, to BMW 530i, as long as the car with sports can be regarded as its competitor.
丰田锐志改装改装低姿态在国内已经非常的大众化,因为太美了,受到很多车友的认可,以至于开着锐志不改装都不好意思出门,今天给大家分享一下丰田锐志改装气动避震的最美低趴效果。
Toyoda Ruizhi refitting low profile has been very popular in China. Because it is so beautiful, it has been recognized by many riders, so I feel embarrassed to go out without refitting. Today, I would like to share with you the most beautiful low lying effect of modified pneumatic shock absorber.
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
Pneumatic shock absorption
话说这是个什么东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器,螺旋弹簧+减震筒形式原理十分类似,只不过通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往,能提供更好的性能表现嗯!就是这么自信
So what is this? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is such a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system. It is actually similar to the air pressure reduction system The principle of shock absorber is very similar to that of common shock absorber, coil spring + shock absorber tube, except that by changing the volume of air chamber (up and down direction), the distance between the body and the ground can be adjusted and the soft and hard characteristics can be changed to a certain extent. In addition, the size of air vent can be changed by the motor to adjust the attenuation force of the shock absorber. Therefore, the air shock absorber can often provide better performance Can show, um! So confident
