查看: 657|回复: 0
凯迪拉克ATS改装气动避震悬挂姿态很美舒适性
发表于 2020-12-21 15:21:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Cadillac ATS modified pneumatic shock absorber suspension posture is very beautiful and comfortable
凯迪拉克ATS是凯迪拉克集合产品设计、研发以及性能调教领域的最新成果而打造的一款全新轻量化后驱车型,于2012年1月在美国底特律北美国际车展中全球首发。
2013年11月21日,ATS在广州车展宣布以全进口方式上市,价格区间为30.8-43.8万元人民币。该车型的主要竞争对手为宝马3系、奔驰C级以及奥迪A4L等。
In 2012, Dirac's lightweight car design was launched in the U.S. in the field of light-weight car design, and the latest product was built in the U.S. in January 2012.
On November 21, 2013, ATS announced in Guangzhou auto show that it would be listed in the form of full import, with a price range of RMB 308000-438000. Its main competitors are BMW 3 series, Mercedes Benz C-class and Audi A4L.
玩改装首先要找准方向,玩姿态就要放弃一定的舒适性,玩性能就不要去考虑油耗。想要玩气动避震低姿态对车子舒适性的要求就不要太高,当然也不是绝对,有些车型改装还是有一定效果的提升,主要看避震调校和车型底盘调校!今天这辆凯迪拉克改装气动避震悬挂,姿态很美,就够了!一起来欣赏凯迪拉克ATS的低趴魅力!
Play refit first to find the right direction, play posture must give up certain comfort, play performance do not consider fuel consumption. If you want to play with pneumatic shock absorbers, the requirements for the comfort of the car should not be too high. Of course, it is not absolute. Some models have been refitted to improve their effects. It mainly depends on the shock absorption adjustment and the vehicle chassis adjustment! Today, this Cadillac is refitted with pneumatic shock absorber suspension. Its posture is very beautiful. That's enough! Let's enjoy the charm of Cadillac ATS!
