查看: 600|回复: 0
时尚的表达 高尔夫7改装气动避震低姿态与时尚接轨
发表于 2020-12-21 14:50:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The expression of fashion Golf 7 refitting pneumatic shock absorber low attitude and fashion integration
高尔夫7是指高尔夫第7代产品。2013年12月10日,一汽-大众全新高尔夫7在广州正式上市。德国大众于1974年推出高尔夫1代产品,至今已经历7次换代了。高尔夫1代到7代是由老到新不断更新换代的一个车型。
每代外型都是有比较大的差异的。国内一汽大众公司在03年7月将四代高尔夫引入中国,并于09年10月引入高尔夫6代。
Golf 7 refers to the seventh generation of golf products. On December 10, 2013, FAW Volkswagen New Golf 7 was officially launched in Guangzhou. German Volkswagen launched the first generation of golf products in 1974, which has gone through seven generations. Golf generation 1 to 7 is a car model constantly updated from old to new.
The appearance of each generation is quite different. FAW Volkswagen introduced the fourth generation of golf into China in July 2003 and the sixth generation in October 2009.
在HellaFlush风格的改装车中,除了对轮毂的J值、ET值以及夸张的Camber等参数极其讲究,剩下的一个重要问题就是降低车身了。那么很多朋友就会直接选择绞牙避震,因为绞牙避震既能降低车身高度,还能提供给车辆充足的支撑性,一举多得,受到不少车友的欢迎。不过对于HellaFlush的那些终极玩家来讲,绞牙避震早已经不能满足他们对“低”需求,所以气动避震(充气式避震器)便凭借着它的能屈能伸的本领赢得了这些终极玩家的芳心。
In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
