查看: 660|回复: 0
潮流之选 别克凯越改装气动避震姿态魅力低趴彰显
发表于 2020-12-21 14:30:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The trend choice Buick Kayue refits the aerodynamic shock absorption posture charm to show low lying
别克凯越(Buick Excelle),基于通用汽车全球平台。凯越的原型车为通用汽车最新开发的全球化中级轿车,由通用大宇汽车科技公司(GMDAT)主导设计和开发。2003年4月21日,上汽 通用汽车的全新中级车,被称为“中别克”的凯越上市。上汽   通用汽车隆重推出基于全新产品平台的“别克凯越Buick Excelle”,从而正式进军极具潜力的中级车市场。
2019年9月18日,别克凯越国六上市  ,推出了搭载1.3L自然吸气发动机的3款车型,售价8.39-9.99万元。  新车搭载新一代别克eConnect互联技术,标配6安全气囊,车身高强度钢使用比例达65%。
Buick Excelle, based on GM's global platform. Kaiyue's prototype car is the latest global intermediate car developed by general motors, which is designed and developed by GM Daewoo automotive technology company (gmdat). On April 21, 2003, SAIC GM's new intermediate car, known as the "Buick" Kaiyue, went on the market. SAIC GM grandly launched the Buick Excelle based on the brand-new product platform, thus officially entering the potential intermediate vehicle market.
On September 18, 2019, Buick Kayue national VI was launched on the market, and three models equipped with 1.3L naturally aspirated engine were launched, with the price of 83900-99900 yuan. The new car is equipped with a new generation of Buick econnect interconnection technology, with 6 airbags as standard. The proportion of high-strength steel used in the car reaches 65%.
别克凯越这个车在国内改装的案例相当少,改装气动避震应该没有,这个车改装气动避震低姿态应该也算是极品了,这款车中规中矩,没什么突出的地方,想要改出不一样的风采就要从姿态开始,所谓“一低遮百丑,百改降为先”气动避震就是不二之选, 做为台湾AIRBFT的最新产品,做工的设计方面也是独一无二的!让我们欣赏别克凯越改装AIRBFT气动悬挂的完美姿态
Buick Kaiyue is a very rare car that has been refitted in China. There should be no aerodynamic shock absorbers. The low attitude of this car should be regarded as the best. This car is regular and has no outstanding points. If you want to change the style, you should start from the posture. The so-called "one low covers all the ugliness, and the hundred changes are reduced to the first" pneumatic shock absorber is the only choice, As the latest product of airbft in Taiwan, the design of workmanship is also unique! Let's enjoy the perfect posture of Buick Kayue refitting airbft pneumatic suspension
下面就来一步步的分解一下:
The installation of pneumatic shock absorber is divided into four parts, that is, the installation of pneumatic shock absorber, the laying of pipelines, the travel of lines, and the installation of control system!
Let's talk about the installation of pneumatic shock absorber. The installation of pneumatic shock absorber barrel body is actually the same as that of replacing ordinary hinge suspension. Shock absorbers are all the installation positions of the original vehicle. It should be noted that the highest and lowest range required by the owner of the vehicle should be calculated according to the shock absorber travel, so as to adjust the height of the solar shock absorber, as well as the reserved position of the air pipe. Generally, the air pipe moves on the inner side The rest is to follow the normal shock absorber installation procedures.
The laying of pipelines and pipelines is a time-consuming work. The methods and ideas of each installation master are different. However, one principle should be followed, that is, to avoid the places that may be bent dead or where the vehicle may be pressed or ground to the air pipe, and that is, to keep away from the exhaust gas, because the material of the gas pipe is prone to high temperature, the best way is to It's going with the tubing.
When the line moves, the line usually goes in the car, along with the electrical circuit in the car, which is quite troublesome, because it is necessary to dismantle a lot of interior parts. It is better not to cut off the main power line. In addition, if there are other electrical equipment in the car, the power line must not be shared to prevent mutual interference.
For the installation of control system, airbft pneumatic shock absorber control system is a simple control system. However, if you want to perfect the installation, you need to have some experience, because there are many details that need to be paid attention to, especially the screw thread connection of each joint, air pipe and air hole, should be carefully installed. The screw tooth connection of air hole and joint must be well sealed, and if there is leakage Gas condition, and then check the test, is very troublesome, as far as possible one step in place.
