查看: 696|回复: 0
福特野马气动避震低姿态改装优雅不失狂野
发表于 2020-12-20 15:51:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
福特野马气动避震低姿态改装优雅不失狂野
Ford Mustang pneumatic shock absorber low attitude refitting elegant without losing wild
由于Mustang I野马概念车的两座设计实用性太低,被福特高层驳回后,1963年10月,福特推出了Mustang II概念车,将布局改为了发动机前置,并采用四座布局。1964年4月17日,经过福特团队反复论证、修改后的第一代量产版Mustang于纽约世博会上正式发布,野马自此正式向全世界展示了它的风范,在刚推出时的价格为:2368美元。福特的时间表把握得非常之巧,此时正值战后生育高峰期的一代刚刚进入购车的年龄,这一代人对车的要求与其父母大相径庭,他们想张扬自己的个性,野马应运而生。
As the Mustang I Mustang concept car's two seat design was too low for practical use, it was rejected by Ford's senior management. In October 1963, Ford launched Mustang II concept car, changing the layout to the front of the engine and adopting a four seat layout. On April 17, 1964, Mustang, the first generation of mass production version, was officially released at the New York World Expo after repeated demonstration and modification by the Ford team. Since then, Mustang has officially demonstrated its style to the world. The price at the time of its launch was 2368 US dollars. Ford's schedule is very skillful. At this time, the generation of postwar baby boomers is just entering the age of buying cars. This generation's requirements for cars are quite different from their parents. They want to show their personality, so Mustang emerges as the times require.
