查看: 618|回复: 0
“史上最强雅阁”本田八代雅阁改装气动避震悬挂低姿态迎合潮流
发表于 2020-12-20 14:33:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The strongest accord in history" Honda 8-generation accord refits pneumatic shock absorber suspension to meet the trend
第八代雅阁的开发设计理念是“Advanced-Powerful”,意味着“前瞻科技和激越力量”完美融合,根据这种理念,本田技研汇聚最新技术,开发了全新的技术平台,从而在空间设计、安全性、动力性能、操控性以及环保等诸多方面,都体现了对本田全球DNA的最完美的诠释。第八代雅阁全面超越突破自我,自诩为“史上最强雅阁”。
第八代雅阁是本田技术的集大成者的完美体现,是雅阁31年品牌历史的巅峰之作。除了在技术全面领先对手,无论从外形和空间的尺寸大小,还是内饰和配置的豪华程度等诸多方面都超越了同级在造型方面,第八代雅阁遵循“刚劲有力”的设计理念,体现了大气、高档、先进、尊贵的设计方向,前脸的设计更具英气,棱角形的大灯和进气隔栅、外张的翼子板等,展现出动感干练的气质。特别是车身侧面贯穿首尾的那条腰线,就像中国书法中的一撇,遒劲有力,却不乏动感,令人过目难忘。
The development and design concept of the eighth generation Accord is "advanced powerful", which means the perfect integration of "forward-looking technology and exciting power". According to this concept, Honda technology research has gathered the latest technology and developed a new technology platform, thus reflecting the most perfect interpretation of Honda's global DNA in space design, safety, power performance, controllability and environmental protection Explanation. The eighth generation of accord surpasses itself in an all-round way and boasts itself as the "strongest accord in history".
The eighth generation Accord is the perfect embodiment of Honda's technology and the peak of accord's 31 year brand history. In addition to leading the competitors in technology, it has surpassed its peers in terms of shape and space size, interior decoration and luxury of configuration. In terms of modeling, the eighth generation Accord follows the design concept of "strong and powerful", reflecting the design direction of atmosphere, high-grade, advanced and noble. The design of the front face is more heroic, with corner shaped headlights and air intake grille The outspread fender shows a dynamic and capable temperament. In particular, the waistline running through the front and rear of the car body is like a stroke in Chinese calligraphy. It is powerful but dynamic, and unforgettable.
本田八代雅阁气动避震桶身信息介绍,专车专用,完美的装车数据,无损安装,让此款车型降的更低,升的更高,更好的展现低姿态!
Honda eight generation Accord pneumatic shock absorber barrel body information introduction, special vehicle dedicated, perfect loading data, non-destructive installation, let this model lower, higher, better show low attitude!
