查看: 774|回复: 0
超跑雄风奥迪TT改装气动避震,完美诠释充满活力的低趴姿态!
发表于 2020-12-20 14:08:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Super running style Audi TT refitted with pneumatic shock absorber, perfectly interprets the dynamic low lying posture!
奥迪TT是奥迪公司开发的一款跑车,1998年首次上市。作为运动型轿车,TT型以它几乎和概念车版相同的漂亮外形,出色的性能在市场上取得了很大的成功。
奥迪TT第一代早期的车型有车主抱怨高速转弯不稳定并发生车祸,Audi调整TT的悬吊系统并在车尾加上后扰流板,使Audi TT的车尾上扬力在时速125英哩时从148磅大幅减为53磅,低于同时期同时速下BMW Z3 Coupe的64磅车尾上扬力和保时捷Boxster的68磅,奔驰SLK的104磅。
Audi TT is a sports car developed by Audi company. It was first launched in 1998. As a sports car, TT has achieved great success in the market with its beautiful appearance and excellent performance almost the same as the concept car version.
In the first generation of Audi TT, the owners complained about unstable turning at high speed and accidents. Audi adjusted the suspension system of TT and added a rear spoiler to the rear of the car, which greatly reduced the rear lift of Audi TT from 148 pounds to 53 pounds at 125 miles per hour, which was lower than the 64 pounds of BMW Z3 coupe, 68 pounds of Porsche Boxster and 104 pounds of Mercedes Benz SLK.
一辆车要想达到一个完美的姿态效果,一套合适的气动避震悬挂是很重要的,紧跟潮流才能让旧版的车型恢复年轻的活力,现在最流行的是什么?最吸引目光的当数气动避震,当气子在车主遥控操作下忽高忽低,想必想不注意都不行吧,奥迪TT改装气动避震以充满活力的低趴身姿,肆意穿梭,自如游弋,可谓是富有进取精神的当代超级跑车。
If a car wants to achieve a perfect posture effect, a set of suitable pneumatic suspension is very important. Keeping up with the trend can make the old model recover its youthful vitality. What is the most popular now? The most attractive thing is pneumatic shock absorbers. When the gas zips up and down under the remote control of the car owners, I think it's impossible to pay attention to them. Audi TT refitted pneumatic shock absorbers, with a dynamic low lying posture, can be described as a modern super running car with enterprising spirit.
