查看: 540|回复: 0
这才是真爱 凌度改装气动避震彻底爱上低姿态尽显低趴魅力
发表于 2020-12-19 15:05:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
This is true love, lingdu refitted pneumatic shock absorber, falling in love with low posture, showing the charm of low lying down
凌渡(Lamando)是上汽大众2014年8月在成都车展推出的一款紧凑型新车。
上汽大众将凌渡定义为“首款宽体轿跑车”,其基于MQB平台打造,搭载EA888 TSI、EA211 TSI发动机,采用湿式7速双离合变速器。
主打高端,属运动型紧凑车,定位于朗逸和帕萨特之间。
Lamando is a new compact car launched by SAIC Volkswagen in Chengdu auto show in August 2014.
SAIC Volkswagen defines lingdu as "the first wide body coupe", which is built on the MQB platform, equipped with EA888 TSI and ea211 TSI engines, and adopts a wet 7-speed dual clutch transmission.
It mainly focuses on high-end, and is a sports compact car, which is positioned between Langyi and Passat.
改装界流行一句话叫"百改降为先“我再补充一句,低趴才是王道! 在整车外形上凌渡还是比较低调不张扬的,两侧扁平不失锐利的大灯被上下两根金属镀铬条连接起来显得很是整齐不过又不失力量感,从前脸看过去,凌渡仿佛被加了宽体一般任何的改装,如果没有气动避震改装的话,我感觉就像行尸走肉,徒有一个光鲜的外表,没有灵魂!正所谓一低遮百丑,气动避震改装是提升整车气质最关键的一笔!
There is a popular saying in the field of refitting that "100 changes should be reduced to the first". I will add that low lying is the king's way! In terms of the vehicle's appearance, lingdu is relatively low-key and unobtrusive. The flat and sharp headlights on both sides are connected by two metal chrome plated strips, which is neat but powerful. Looking from the front, it seems that lingdu has been modified with a wide body. If there is no pneumatic shock absorber, I feel like a walking corpse with a bright appearance, No soul! As the so-called low cover hundred ugliness, pneumatic shock absorber refitting is the most critical to improve the quality of the vehicle!
AIRBFT专用气囊:
Airbft special airbag:
Like airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue times 3 million to 5 million times, normal use of 3-5 years no problem! All the airbags are tested by strict testing equipment to test the pressure, and then they can be sold together! The clamp part of the leather bag is compressed by high-pressure locking equipment, and the normal pressure test is at 200psi, explosion-proof! The outer layer of the leather bag is protected by anti-corrosion, rain, sand and dust resistant materials! Give you the safest protection
