查看: 757|回复: 0
宝马5系旅行E61AIRBFT气动避震改装完美落地
发表于 2020-12-19 13:52:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 5-series travel e61airbft pneumatic shock absorber refitted to a perfect landing
宝马5系旅行轿车是宝马旗下的一款旅行轿车,采用了全新LED头灯,外形的设计与7系相似。
新车采用轻量化设计,车重将减轻100公斤。宝马对新车的四缸和六缸发动机进行了升级,还将提供530e和540e两种混合动力供选择。
从5系旅行插电式车型的最新谍照看,车身尺寸依旧很大,并且在车头以及尾部地方还采用了全新7系的设计元素,整体的外观看上去也更加激进运动;另外,由于全新7系的车身重量比上代车型有所降低,全新5系的车身重量大约会比现款车型降低约100公斤。
至于动力方面,宝马全新5系旅行插电式车型将会搭载一台2.0T涡轮增压发动机,在配合9千瓦时的锂离子电池组,综合功率达到了230kW,峰值扭矩更是达到了450Nm;传动方面匹配了8速Steptronic变速器,并且还带有手动换挡方式。
The BMW 5-series touring car is one of BMW's saloon cars. It adopts a new LED headlamp, and its shape design is similar to that of the 7 series.
The new car adopts lightweight design, and the weight will be reduced by 100 kg. BMW has upgraded its four cylinder and six cylinder engines, and will offer 530e and 540e hybrids.
According to the latest spy photos of the 5-series travel plug-in model, the body size is still very large, and the new 7-series design elements are adopted in the front and rear of the vehicle, so the overall appearance looks more radical. In addition, as the body weight of the new 7 series is lower than that of the previous model, the body weight of the new 5 series will be about 100 kg lower than that of the current model.
In terms of power, BMW's new 5-series travel plug-in model will be equipped with a 2.0T turbocharged engine. With a 9-kilowatt-hour lithium-ion battery pack, the comprehensive power reaches 230kw, and the peak torque reaches 450nm. In terms of transmission, it is equipped with an 8-speed steptronic transmission and also has a manual shift mode.
宝马5系旅行版E61确实是罕见的车种,据了解,这台车原本就是空气悬挂(和气动避震改装是一个原理),但是为什么要再次改装呢?
原车的空气悬挂大多都是以舒适性为主,像这么出色的宝马系列当然不满足仅有的舒适性了,还有就是升降的幅度和速度,现在年轻人都是希望自己的爱车是独一无二的,想要独特,那就要对爱车进行改装,下面这台来自台湾朋友分享的宝马E61,改装气动避震+轮毂的搭配,低姿态看起来是那么的协调美观,“一低遮百丑”真心不假!
BMW 5-series travel E61 is indeed a rare type of car. It is understood that this car was originally air suspension (and pneumatic shock absorber modification is the same principle), but why refit it again?
Most of the original car's air suspension is based on comfort. Of course, such an excellent BMW series does not satisfy the only comfort, but also the range and speed of lifting and falling. Now young people want their car to be unique. If they want to be unique, they need to modify their car. The following BMW E61, shared by friends from Taiwan, is refitted with pneumatic shock absorber and wheel hub The collocation, low posture looks so harmonious and beautiful, "one low cover hundred ugliness" is true!
People who like pneumatic shock absorber like it to the bone. People who don't like it may never like it. Maybe they don't understand it. Here I'd like to introduce it
Refitting pneumatic shock absorber: pneumatic shock absorber is the most popular modification project recently. Its simple modification steps (which can be installed at home) and the feature of no damage to the body parts can satisfy the owners who want to refit and are afraid to hurt their car. The simple and flexible control and comfort are still the items that the owners still like. The above advantages make them happy Pneumatic shock absorbers are more common
Operation, airbft pneumatic shock absorber has four wheels independent operation (four wheels can independently control height, software and hardware), three-stage memory function (it can remember that the height of three cars is low, for example: 1 button is set to the lowest prone state, 2 button can be set to be the original vehicle height or the most comfortable height when driving, and 3 buttons can be set to the highest height of general vehicle Wireless remote control (remote control, pneumatic control)
Modeling: car owners can set the shape and color of pneumatic shock absorber control system according to their own requirements.
Space: the pneumatic control system is generally placed in the trunk. The space occupied by the pneumatic control system is the same as that of a car's spare tire. It can be hidden in the spare tire or in the corner of the trunk. It can be protected by customized wooden box, which can not only save space, but also put East and West.
