查看: 629|回复: 0
kia stinger改装气动避震悬挂 这姿态效果真是美爆了
发表于 2020-12-19 13:40:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
kia stinger改装气动避震悬挂 这姿态效果真是美爆了Kia stinger refitted pneumatic suspension, which is really amazing
改装就是让自己的车与众不同。有个性,有魅力,对于城市SUV很多人只是为了有更好的空间和实用性,改装一般人不会去考虑,今天我们来看看这辆kia stinger的姿态改装,真是颠覆了我们的思想!
Refitting is to make your car different. It has personality and charm. For urban SUV, many people just want to have better space and practicability. Ordinary people will not consider refitting it. Today, let's take a look at the posture modification of this Kia singer. It really subverts our ideas!
