查看: 714|回复: 0
出彩更出色 野马5.0改装气动避震悬挂的完美姿态
发表于 2020-12-18 16:29:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect posture of Mustang 5.0 modified pneumatic suspension
野马5.0外观设计比起上一代更加的时尚,流线设计更具跑车范,改装气动避震悬挂低姿态效果更是完美,国内的野马党就骚动起来,一台接着一台的改装低趴风格,来欣赏这辆打造的野马气动避震悬挂低趴!
Compared with the previous generation, the appearance design of Mustang 5.0 is more fashionable, the streamline design is more sports car style, the modified pneumatic shock absorber suspension low posture effect is more perfect, the domestic Mustang party is in a commotion, one by one refitting low lying style, to appreciate the Mustang pneumatic shock absorption suspension low lying!
