查看: 628|回复: 0
“老车才是经典,有的不仅是情怀”老款皇冠AIRBFT气动避震施工
发表于 2020-12-18 15:31:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Old car is classic, some are not only feelings" old crown airbft pneumatic shock absorber construction
Crown is a large and medium-sized car brand of Toyota group. Toyota Crown was launched in Japan on January 1, 1955. There are more than the 13th generation models. The domestic crown engines are 2.5L, 3.0L and 4.3L. The first two engines are V6 cylinder 24 valve design, and the 4.3L engine is V-type eight cylinder. Dual VVT-i intelligent timing variable system of inlet and outlet valves is configured.
The intake efficiency, fuel economy and power performance of the engine are greatly improved, and the horsepower is more powerful. In terms of chassis, it adopts four-wheel fully independent suspension, which is very comfortable.
戒不掉的改装情怀,自从气动避震的改装传入国内以来,就受到广大车友的疯狂追捧,因为可以随时的升降车身底盘的高度,改变了一成不变的驾驶模式,AIRBFT气动避震改装停车的时候降至最低来享受视觉的冲击,开车的时候还有3种不同高度模式可选择,成为了很多车友改装的首选!
Since the modification of pneumatic shock absorber was introduced into China, it has been wildly sought after by the vast number of riders. Because the height of the body chassis can be raised and lowered at any time, the unchangeable driving mode has been changed. Airbft pneumatic shock absorber is refitted to minimize the impact of vision when parking, and there are three different height modes to choose from when driving The first choice of refitting for many riders!
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
Pneumatic shock absorption
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
So what is this?
But its working medium is gas
And electronic control system
The principle is very similar
It's just
Yeah! So confident
