查看: 633|回复: 0
当下最流行的汽车改装风格 经典福克斯改装气动避震
发表于 2020-12-18 14:59:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The most popular car modification style at present
福特·福克斯 FOCUS的意思就是焦点。 福克斯作为福特旗下最畅销的紧凑型轿车,以其良好的底盘和操控性,提升了福特在全球市场的品牌地位。
1998年,福克斯问世,出色的操控性能和运动化的底盘调校使其快速风靡全球。2005年,福克斯携WRC世界越野拉力赛一身荣耀进入中国,到2019年已在CTCC中国房车竞标赛中获得了十三年九冠的传奇战绩,以“运动时尚”定义了运动轿车。
福克斯从第二代车型开始进入中国市场以后,以运动、操控见长和年轻、动感为主要形象,在国内紧凑级车型市场取得了良好的成绩,随着车型日益成熟,消费者的年龄层也产生着小幅变化,客户群的年龄范围更广。
历经14年耕耘,追逐驾驶乐趣的福克斯从未止步,到2019年已得到了260万中国消费者的喜爱。此次焕新升级的新一代福克斯2020款在传承福克斯品牌基因的同时,其兼具操控性、舒适性与智能互联。
Ford Focus means focus. As Ford's best-selling compact car, fox has enhanced Ford's brand position in the global market with its good chassis and handling.
In 1998, fox came out. Its excellent handling performance and sporty chassis adjustment make it popular all over the world. In 2005, fox entered China with WRC world cross-country rally with glory. By 2019, fox had won the legendary record of nine Championships in CTCC China RV competition for 13 years, and defined sports car with "sports fashion".
After entering the Chinese market from the second generation, fox has made good achievements in the domestic compact car market with its sports, handling expertise, youth and dynamic as its main image. With the increasingly mature models, the age group of consumers has also changed slightly, and the age range of customers is wider.
After 14 years of hard work, the pursuit of driving fun fox has never stopped. By 2019, it has been loved by 2.6 million Chinese consumers. The newly upgraded fox 2020 model not only inherits the Fox brand gene, but also has the controllability, comfort and intelligent interconnection.
气动避震底盘升降悬挂系统是近几年的一个改装热门,很多的玩家开始了低姿态的改装路线,以前的底盘升降成本太高,很多人望而却步,随着改装行业的发展,现在的气动避震悬挂已经很普遍,价格也算平民化了,各种车型的安装案例也是越来越多, 国产车也有很多人在玩了,今天我们来欣赏的是福克斯改装AIRBFT气动避震低姿态案例,改装不分高低贵贱。
Pneumatic shock absorber chassis lifting suspension system is a popular modification in recent years. Many players have started low-profile refitting routes. In the past, the cost of chassis lifting was too high, and many people were deterred. With the development of the refitting industry, the pneumatic shock absorber suspension is now very common, and the price is civilian. There are more and more installation cases of various models, Many people are playing with domestic cars. Today, we are going to appreciate the case of fox refitting airbft pneumatic shock absorber with low attitude, regardless of whether it is high or low.
下面就来一步步的分解一下:
The installation of pneumatic shock absorber is divided into four parts, that is, the installation of pneumatic shock absorber, the laying of pipelines, the travel of lines, and the installation of control system!
Let's talk about the installation of pneumatic shock absorber. The installation of pneumatic shock absorber barrel body is actually the same as that of replacing ordinary hinge suspension. Shock absorbers are all the installation positions of the original vehicle. It should be noted that the highest and lowest range required by the owner of the vehicle should be calculated according to the shock absorber travel, so as to adjust the height of the solar shock absorber, as well as the reserved position of the air pipe. Generally, the air pipe moves on the inner side The rest is to follow the normal shock absorber installation procedures.
The laying of pipelines and pipelines is a time-consuming work. The methods and ideas of each installation master are different. However, one principle should be followed, that is, to avoid the places that may be bent dead or where the vehicle may be pressed or ground to the air pipe, and that is, to keep away from the exhaust gas, because the material of the gas pipe is prone to high temperature, the best way is to It's going with the tubing.
When the line moves, the line usually goes in the car, along with the electrical circuit in the car, which is quite troublesome, because it is necessary to dismantle a lot of interior parts. It is better not to cut off the main power line. In addition, if there are other electrical equipment in the car, the power line must not be shared to prevent mutual interference.
For the installation of control system, airbft pneumatic shock absorber control system is a simple control system. However, if you want to perfect the installation, you need to have some experience, because there are many details that need to be paid attention to, especially the screw thread connection of each joint, air pipe and air hole, should be carefully installed. The screw tooth connection of air hole and joint must be well sealed, and if there is leakage Gas condition, and then check the test, is very troublesome, as far as possible one step in place.
