查看: 724|回复: 0
昂克赛拉改装气动避震展现个性低趴之美
发表于 2020-12-18 13:56:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
昂克赛拉改装气动避震展现个性低趴之美
Onksila refitted pneumatic shock absorber to show the beauty of low lying personality
马自达3昂克赛拉,是由长安马自达汽车生产的一款汽车,采用新一代“创驰蓝天”技术和全新设计主题“魂动”的第三款车型,在2014年北京车展首发。
该车型将搭载两款创驰蓝天汽油发动机,首次导入中国市场的“SKYACTIV-G 1.5L”和具备高效动力的“SKYACTIV-G 2.0L”。
Mazda 3 onksila, a car produced by Changan Mazda, is the third model with a new generation of "chuangchi blue sky" technology and a new design theme of "soul". It was first launched in 2014 Beijing auto show.
This model will be equipped with two types of chuangchi blue sky gasoline engines, which will be introduced into the Chinese market for the first time, namely "skyactiv-g 1.5L" and "skyactiv-g 2.0L" with efficient power.
改装是每一个玩车人都必经一个阶段,原厂件虽然耐用但是美观程度却不行,所以所外观姿态比较讲究的玩家就会对车子进行改装,就出现了很多的改装风格,比如:VIP、Hellaflush等。今天我们来欣赏昂克赛拉改装AIRBFT气动避震悬挂的低趴风格,只改了减震效果不是很好,期待更换轮毂数据的完美姿态!
Refitting is a stage that every player has to go through. Although the original parts are durable, they are not good-looking. Therefore, players who pay more attention to the appearance and posture will refit the car, resulting in many modification styles, such as VIP, hellaflush, etc. Today, we'd like to appreciate the low lying style of onksella's modified airbft pneumatic suspension, only the shock absorption effect is not very good, looking forward to the perfect posture of changing the wheel hub data!
所谓改装车,按照我个人的理解,就是两个改装路线,性能和姿态。当然,有不少改装玩家对于性能和姿态都想兼顾,这样的想法是好的,但是却很难真正实现,以后我们专门找个机会讨论关于性能和姿态不可兼得的问题。今天我们来讨论的就是走姿态路线改装车的终极武器,气动避震
he so-called refitted vehicle, according to my personal understanding, is two refitting routes, performance and posture. Of course, there are many modified players who want to give consideration to both performance and posture. This is a good idea, but it is very difficult to really achieve it. In the future, we will take a special opportunity to discuss the issue of not having both performance and posture. Today we're going to talk about the ultimate weapon of the attitude modification vehicle, pneumatic shock absorption
AIRBFT专用气囊:
Airbft special airbag:
