查看: 652|回复: 0
大众CC改装气动避震 当车子降到最低的那一刻颜值彻底爆棚
发表于 2020-12-17 13:49:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen CC refits pneumatic shock absorber, when the car is reduced to the lowest point, its appearance is completely destroyed
一汽-大众CC是一汽-大众旗下一款运动型的轿车。
一汽-大众CC将轿车的稳定性与跑车的灵敏度结合。它采用4门无框设计,内饰具有运动风格,延续了大众汽车商务轿车系列车型的风格,真皮跑车座椅以及真皮智能运动型方向盘。
FAW Volkswagen CC is a sports car owned by FAW Volkswagen.
FAW Volkswagen CC combines the stability of cars with the sensitivity of sports cars. It has a 4-door frameless design and sporty interior, continuing the style of the Volkswagen business sedan series, leather sports seats and leather intelligent sports steering wheel.
大众CC是德国设计师团队潜心研制的结晶,CC所有的设计元素都从豪华车中提取,放大并超越,达到其他车型所无法企及的境界,外观延续了优雅身形,并保持了成熟商务的质感。可以说的上是完美了,但是下面这几辆车的车主仍不安于现姿态,改装了气动避震,追求低趴姿态,感觉还不错!
Volkswagen CC is the crystallization of German designer team. All design elements of CC are extracted from luxury cars, amplified and surpassed, reaching a level that other models can't reach. The appearance continues the elegant body shape and maintains the texture of mature business. It can be said that it is perfect, but the owners of the following cars are still not satisfied with the current posture. They have refitted the pneumatic shock absorber to pursue a low prone posture, which is quite good!
There are two main types of shock absorber from the angle of hydraulic damper.
