查看: 590|回复: 0
奥迪A7气动避震低姿态改装帅气有范
发表于 2020-12-17 13:26:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奥迪A7气动避震低姿态改装帅气有范
Audi A7 pneumatic shock absorber low profile modification, handsome and elegant
对待生活中的每一天若都像生命中的最后一天去对待,人生定会更精彩。奥迪车身造型整体感很强,各元素之间相互呼应;外观处理简洁、硬朗;线条运用精准、流畅,每一处都展现出融合科技与时尚的美学特性。气动减震器的工作原理就是通过控制气压来改变车身高低,其包括弹性橡胶气囊减震器、气压控制系统、后备箱储气罐和电子控制系统等。今天跟大家分享奥迪A7改装气动避震完美的蜕变
If you treat every day in your life like the last day in your life, your life will be more wonderful. Audi's body shape has a strong sense of integrity, and the elements echo with each other; the appearance is simple and strong; the lines are precise and smooth; every part shows the aesthetic characteristics of integration of technology and fashion. The working principle of pneumatic shock absorber is to control the air pressure to change the height of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system. Today, I would like to share with you the perfect transformation of Audi A7 pneumatic shock absorber
『气动减震器,能够轻易改变车身高度』李洋
