查看: 609|回复: 0
简洁至上,十代雅阁改装气动避震低趴风格
发表于 2020-12-16 14:57:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
简洁至上,十代雅阁改装气动避震低趴风格
Simple first, ten generations of accord refitted pneumatic shock absorber low prone style
修长的前鼻和凌厉的腰线,刻画出野性不羁的姿态。与生俱来的运动基因,唤醒了内心的野性,从空气动力学中汲取时尚灵感,打破传统美学准则,瞬间锁定你的眼球,让你一目难忘,是谁在放肆,美到犯规,这是对十代雅阁的外观评价,跨时代的设计绝对会大有所获。
Long nose and sharp waistline, depicting the wild uninhibited posture. The inborn sports gene awakens the wildness of the heart. It draws fashion inspiration from the aerodynamics, breaks the traditional aesthetic standards, and instantly locks your eyes. It makes you unforgettable who is reckless and beautiful to violate the rules. This is the appearance evaluation of the ten generation Accord, and the cross era design will definitely gain a lot.
十代雅阁是一个经典车型,目前最新款的是第十代雅阁,外观设计和第九代做了全面的改变,全新改款,销量也还可以,更符合年轻人的选择,今天我们来欣赏十代 雅阁改装AIRBFT气动避震低趴案例,完美的姿态效果,让人心旷神怡!
The 10th generation Accord is a classic model, and the latest one is the 10th generation Accord. The appearance design and the 9th generation have been changed comprehensively. The brand-new model can also be sold well, which is more in line with the young people's choice. Today, we'd like to appreciate the case of the 10th generation Accord refitting airbft pneumatic shock absorber low lying prone. The perfect posture effect makes people relaxed and happy!
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
Pneumatic shock absorption
So what is this?
But its working medium is gas
generally speaking, it's a set of things like this shown in the figure below
And electronic control system
The principle is very similar
It's just
Yeah! So confident
