查看: 644|回复: 0
奥迪A3改装气动避震悬挂展现姿态的极致升华
发表于 2020-12-16 11:55:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi A3 modified pneumatic shock suspension shows the ultimate sublimation of posture
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. Its body is made of lightweight design and aluminum material. It is equipped with 1.4tfsi and 1.8tfsi engines.
The front suspension of Audi A3 chassis is McPherson type, and the rear axle is of torsion and crank structure with separate springs and shock absorbers. In addition to excellent maneuverability, the space utilization rate of rear suspension layout is also very high, so the loading area is outstanding among the same class of vehicles. For all A3 series models, the front and rear brakes are disc type, and the front brake is equipped with ventilation groove.
说起奥迪A3,小编在这里也是喜欢的不得了,因为这台车充满了运动的细胞,除了可以接受的噪音外,其他是没有一点毛病,包括操控,动力各个方面都是相当的出色,在加上稍微的改装,简直是完美!
今天说道的这台奥迪A3,经过AIRBFT气动避震的加持,将车身姿态降到了最低,简直是具有超跑颜值的一台小A3,再说,在这个拼个性,讲究颜值的今天,满大街的车子,不改装什么时候才能也得不到关注!连约个妹纸妹纸都不约…
Speaking of the Audi A3, Xiaobian likes it very much here, because this car is full of sports cells. Except for the acceptable noise, there is no problem. The handling and power are excellent. With a little modification, it is perfect!
The Audi A3 we are talking about today, thanks to airbft's aerodynamic shock absorber, has reduced the body posture to the lowest level. It's a small A3 with super running appearance. Besides, in today's competition of personality and beauty, when can cars in the street not be refitted will not be paid attention to! I don't even have a date with my sister
  『气动减震器,能够轻易改变车身高度』李洋
