查看: 942|回复: 0
福特蒙迪欧致胜改装AIRBFT气动避震案例
发表于 2020-12-13 15:43:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The case of air shock absorber refitted by Ford Mondeo Zhisheng
新蒙迪欧致胜,是福特于2011年3月17日发布的一款新车,是长安福特科技含量最高的车型,蒙迪欧在车身及内外饰、零部件设计、制作工艺、用料等方面做了232项工程变更。
且2.0升直喷涡轮增压发动机和六速双离合变速器均为福特最新技术,0-100公里/时加速用时8.3秒,综合路况油耗为7.9升/百公里。
The new Mondeo wins is a new car released by Ford on March 17, 2011. It is the model with the highest technology content of Changan Ford. Mondeo has made 232 engineering changes in the aspects of body, interior and exterior decoration, parts design, manufacturing process and materials.
Moreover, the 2.0 l direct injection turbocharged engine and the six speed dual clutch transmission are the latest technologies of Ford. It takes 8.3 seconds to accelerate 0-100 km / h, and the fuel consumption is 7.9 L / 100 km / h.
2011款蒙迪欧致胜 于2011年3月17日在中国正式上市,根据福特Kinetic Design动态设计路线,新款车型在外观方面有所改动,变化最明显的是前脸进气格栅的面积比重分配,在上进气格栅面积缩小的同时增大下进气格栅的面积,六边形的梯形中网使整个前脸看起来更加稳重,而前后灯组采用了时下流行的LED灯组设计。另外,新车尾部也进行了调整,采用了新的尾部保险杆和尾部反光板。福特蒙迪欧改装AIRBFT气动避震高配改装套件,带有记忆功能,可以实现四轮独立升降,四轮独立微调,前轮同时升降,后轮同时升降,四轮同时升降功能。福特蒙迪欧改装AIRBFT气动避震,感受低趴驾车舒适感!
The 2011 Mondeo Zhisheng was officially launched in China on March 17, 2011 Design dynamic design route, the appearance of the new model has been changed. The most obvious change is the area proportion distribution of the front air intake grille. The area of the upper air intake grille is reduced while the area of the lower air intake grille is increased. The hexagonal trapezoidal middle net makes the whole front face look more stable, and the front and rear light groups adopt the current popular LED lamp group design. In addition, the new car tail has also been adjusted, using a new rear bumper and rear reflector. Ford Mondeo modified airbft pneumatic shock absorber high configuration refitting kit, with memory function, can realize four wheel independent lifting, four wheel independent fine tuning, front wheel lifting at the same time, rear wheel lifting and four wheel lifting at the same time. Ford Mondeo modified airbft pneumatic shock absorber, feel the low lying driving comfort!
下面就来一步步的分解一下:
The installation of pneumatic shock absorber is divided into four parts, that is, the installation of pneumatic shock absorber, the laying of pipelines, the travel of lines, and the installation of control system!
Let's talk about the installation of pneumatic shock absorber. The installation of pneumatic shock absorber barrel body is actually the same as that of replacing ordinary hinge suspension. Shock absorbers are all the installation positions of the original vehicle. It should be noted that the highest and lowest range required by the owner of the vehicle should be calculated according to the shock absorber travel, so as to adjust the height of the solar shock absorber, as well as the reserved position of the air pipe. Generally, the air pipe moves on the inner side The rest is to follow the normal shock absorber installation procedures.
The laying of pipelines and pipelines is a time-consuming work. The methods and ideas of each installation master are different. However, one principle should be followed, that is, to avoid the places that may be bent dead or where the vehicle may be pressed or ground to the air pipe, and that is, to keep away from the exhaust gas, because the material of the gas pipe is prone to high temperature, the best way is to It's going with the tubing.
When the line moves, the line usually goes in the car, along with the electrical circuit in the car, which is quite troublesome, because it is necessary to dismantle a lot of interior parts. It is better not to cut off the main power line. In addition, if there are other electrical equipment in the car, the power line must not be shared to prevent mutual interference.
For the installation of control system, airbft pneumatic shock absorber control system is a simple control system. However, if you want to perfect the installation, you need to have some experience, because there are many details that need to be paid attention to, especially the screw thread connection of each joint, air pipe and air hole, should be carefully installed. The screw tooth connection of air hole and joint must be well sealed, and if there is leakage Gas condition, and then check the test, is very troublesome, as far as possible one step in place.
