查看: 630|回复: 0
“开宝马坐奔驰”奔驰E改装气动避震悬挂奢华低调有内涵
发表于 2020-12-13 14:31:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz has the connotation of luxury and low-key suspension
奔驰E级轿车是奔驰开发出的介于C级与S级之间的一款中大型高端商务轿车,跑车,旅行车,目前公认E级车的鼻祖是1947年的奔驰170,它是战后奔驰开发的第一批车型之一。
与同一年代的170s相比,170的外形较少修饰,装备也进一步简化。1953年,170的改进型180和190继问世。从那时起,奔驰E级车就逐渐形成系列,车身型式有轿车和旅行车两种,汽油机排量有2.0——3.0三种,还可选装柴油机。截止到1961年,170系列总共生产了46.8万辆。全新的奔驰E级轿车已不同以往,全新的E级将分为运动轿车和轿车两大系列,全系也更换了更省油,更强劲的增压发动机。
Benz E-class car is a medium and large-scale high-end business car, sports car and station wagon developed by Mercedes Benz between C-class and S-class. Currently, it is recognized that the originator of E-class car is Benz 170 in 1947, which is one of the first batch of models developed by Mercedes Benz after World War II.
Compared with the 170s of the same era, the 170's shape is less modified and the equipment is further simplified. In 1953, the improved models 180 and 190 of 170 were introduced. Since then, Mercedes Benz E-class cars have gradually formed a series. There are two types of body, car and station wagon, three kinds of gasoline engine displacement (2.0-3.0), and optional diesel engine. By 1961, the 170 series had produced 468000 vehicles. The brand-new Benz E-class sedan is different from the past. The brand-new E-class will be divided into sports car and car series. The whole series has been replaced with more fuel-efficient and stronger supercharged engine.
我经常看一些国外的改装案例,很多车辆都会让人深度着迷,不同于国内大批量“同化”的家用车,国外人更希望自己的爱车成为“买菜车”中最稀有的一辆,当然改装文化氛围的不同也有着很多各方面因素的影响,但是我们都是希望自己的座驾在吸引更多路人目光的同时,也能和大家分享改装的魅力!
I often look at some foreign refitting cases. Many vehicles will make people deeply fascinated. Different from the domestic large-scale "assimilated" family cars, foreigners prefer their own cars to become the rarest among the "buying vegetable cars". Of course, the different cultural atmosphere of refitting also has many factors, but we all hope that our cars can attract more people At the same time, we can share the charm of refitting!
AIRBFT专车专用皮囊,所采用的天然胶成分比轮胎天然胶成分还要多!单次疲劳次数5百万次到8百万次,正常使用3-5年一点问题没有!都是经过严格的测试设备来进行试压 饱压才能出售!在皮囊的卡箍环节经过高压力的锁紧设备,皮囊外层都有防腐蚀 防雨水 防沙尘 耐磨材料层层保护!Airbft special car special leather bag, the use of natural rubber ingredients than tire natural rubber ingredients more! Single fatigue 5 million times to 8 million times, normal use of 3-5 years, no problem! After strict testing equipment to test pressure, full pressure can be sold! Through high-pressure locking equipment, the outer layer of the leather bag is protected by anti-corrosion, rainproof, sand and dust resistant materials!
4: I don't want to use it before and after the installation
