查看: 546|回复: 0
AIRBFT气动避震改装专用气管到货20000米温度-30--120摄氏度压力2.6mpa规格8*1mm
发表于 2020-12-13 14:01:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft pneumatic shock absorber refitted special gas pipe arrives at 20000 m temperature - 30 -- 120 ℃, pressure 2.6MPa, specification 8 * 1mm
下面就来一步步的分解一下:
The installation of pneumatic shock absorber is divided into four parts, that is, the installation of pneumatic shock absorber, the laying of pipelines, the travel of lines, and the installation of control system!
Let's talk about the installation of pneumatic shock absorber. The installation of pneumatic shock absorber barrel body is actually the same as that of replacing ordinary hinge suspension. Shock absorbers are all the installation positions of the original vehicle. It should be noted that the highest and lowest range required by the owner of the vehicle should be calculated according to the shock absorber travel, so as to adjust the height of the solar shock absorber, as well as the reserved position of the air pipe. Generally, the air pipe moves on the inner side The rest is to follow the normal shock absorber installation procedures.
The laying of pipelines and pipelines is a time-consuming work. The methods and ideas of each installation master are different. However, one principle should be followed, that is, to avoid the places that may be bent dead or where the vehicle may be pressed or ground to the air pipe, and that is, to keep away from the exhaust gas, because the material of the gas pipe is prone to high temperature, the best way is to It's going with the tubing.
When the line moves, the line usually goes in the car, along with the electrical circuit in the car, which is quite troublesome, because it is necessary to dismantle a lot of interior parts. It is better not to cut off the main power line. In addition, if there are other electrical equipment in the car, the power line must not be shared to prevent mutual interference.
For the installation of control system, airbft pneumatic shock absorber control system is a simple control system. However, if you want to perfect the installation, you need to have some experience, because there are many details that need to be paid attention to, especially the screw thread connection of each joint, air pipe and air hole, should be carefully installed. The screw tooth connection of air hole and joint must be well sealed, and if there is leakage Gas condition, and then check the test, is very troublesome, as far as possible one step in place.
