查看: 653|回复: 0
法拉利改装AIRBFT气动避震悬挂案例 超跑低趴魅力更强
发表于 2020-12-12 14:42:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ferrari refitted airbft pneumatic shock absorber suspension case super running low lying charm stronger
法拉利 是举世闻名的赛车和运动跑车的生产厂家,总部位于意大利马拉内罗(Maranello)。由恩佐·法拉利(Enzo Ferrari)于1947年创办,主要制造一级方程式赛车、赛车及高性能跑车。
Ferrari is a world-famous manufacturer of racing cars and sports cars with its headquarters in Maranello, Italy. Founded by Enzo Ferrari in 1947, it mainly manufactures Formula One racing cars, racing cars and high-performance sports cars.
法拉利作为超级跑车,很多人对它是绝对的喜欢,这样的超级跑车原车的配置已经很高端,改装只能是锦上添花,但是今天这辆改装的ENDO气动避震悬挂的法拉利姿态更是让人痴迷不已!来欣赏这辆法拉利的魅力低趴!
Ferrari as a super sports car, many people absolutely like it. The original configuration of such a super sports car has been very high-end, and the modification can only add to the icing on the cake. But today, the Ferrari attitude of this modified endo pneumatic shock absorber suspension is even more fascinating! Come and enjoy the charm of this Ferrari!
