查看: 654|回复: 0
野马AIRBFT气动避震设计后备箱造型
发表于 2020-12-11 16:26:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
野马AIRBFT气动避震设计后备箱造型
Mustang airbft pneumatic shock absorber design trunk modeling
In 1962, Ford developed Mustang's first concept car, Mustang I. It's a two seater sports car with a central engine. The name of Mustang is to commemorate the legendary P-51 Mustang fighter in World War II.
新款的野马外观设计比起上一代更加的时尚,流线设计更具跑车范,改装气动避震悬挂低姿态效果更是完美,国内的野马党就骚动起来,一台接着一台的改装低趴风格,来欣赏这辆由HG打造的野马气动避震悬挂低趴!
Compared with the previous generation, the appearance design of the new Mustang is more fashionable, the streamline design is more sports car style, the modified pneumatic shock absorber suspension low posture effect is more perfect, the domestic Mustang party is in a commotion, one by one refitting low lying style, to enjoy the wild horse pneumatic shock absorber suspension low lying made by Hg!
汽车底盘的改装在改装行业现在比重也是很大,原车的底盘系统现在都不能满足玩家的需求,改装势在必行,前几年绞牙避震改装是玩家的主流选择,既降低了车身增加美感又可以提升车辆操控,不过硬度不是一般人能接受的,烂路更是让绞牙党苦不堪言,现在气动避震的出现,让玩绞牙的玩家看到了新的曙光。停车时贴地的低趴效果,行车时又可以升高车身,随意升降真是很爽,调校好的话舒适度比之绞牙更好一点,现在已成为底盘悬挂改装的一个潮流,如果稳定性和舒适性再好一点,未来一定可以成为最流行的改装项目!The refitting of automobile chassis accounts for a large proportion in the refitting industry. The chassis system of the original car can't meet the needs of the players now, so it is imperative to refit. In the past few years, the refitting of twisting teeth and shock absorbers is the mainstream choice of players. It not only reduces the body's beauty, but also improves the vehicle's handling. However, the hardness is not acceptable to ordinary people, and the rotten road makes the grindstone miserable The emergence of dynamic shock absorbers, so that the players playing with the teeth saw a new dawn. The low lying effect of parking is close to the ground, and the car body can be raised when driving. It is really cool to lift and lift at will. If the adjustment is good, the comfort is better than the twisted teeth. Now it has become a trend of chassis suspension modification. If the stability and comfort are better, it will become the most popular modification project in the future!
