查看: 671|回复: 0
福特改装低趴姿态著称的气动避震 颜值立马上升一个本质的飞跃
发表于 2020-12-11 15:28:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford refitted the aerodynamic shock absorber appearance which is famous for its low prone posture, and immediately rose an essential leap
说道汽车的改装文化,因为国内各项政策都还没有完全的开放,所以在街上或者是停车场看到改装车,是一件很幸运的事,因为在国内改装车实在是太少,除了能在改装车展会上能大饱眼福之外,就只有融入到这个改装圈,才能更多的了解和学习改装知识!下面的这台福特改装的是气动避震和轮毂轮胎!就能将气动避震改装的精髓体现出来,极致低的车身姿态,完美的诠释了低趴精神!不得不说是一台改装气动避震的好胚子!在车友聚会或者是停车场停车,缓缓将车子降到最低,想想是多么爽的一件事情!
When it comes to the car refitting culture, because the domestic policies are not fully open, it is a very lucky thing to see modified cars on the street or in the parking lot, because there are too few modified cars in China. In addition to being able to feast our eyes on the modified car exhibition, only by integrating into this refitting circle can we learn more about and learn about refitting! The next Ford is refitted with pneumatic shock absorbers and wheel tires! It can embody the essence of pneumatic shock absorber refitting. The extremely low body posture perfectly interprets the spirit of low lying down! It has to be said that it is a good candidate for refitting pneumatic shock absorber! What a wonderful thing it is to park in a car park or a car park and slowly reduce the car to the lowest level!
