查看: 608|回复: 0
简单大气有档次凌渡改装气动避震尽显低趴魅力
发表于 2020-12-10 15:34:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Simple and elegant, lingdu refitted pneumatic shock absorber shows low lying Charm
凌渡(Lamando)是上汽大众2014年8月在成都车展推出的一款紧凑型新车。
上汽大众将凌渡定义为“首款宽体轿跑车”,其基于MQB平台打造,搭载EA888 TSI、EA211 TSI发动机,采用湿式7速双离合变速器。
主打高端,属运动型紧凑车,定位于朗逸和帕萨特之间。
Lamando is a new compact car launched by SAIC Volkswagen in Chengdu auto show in August 2014.
SAIC Volkswagen defines lingdu as "the first wide body coupe", which is built on the MQB platform, equipped with EA888 TSI and ea211 TSI engines, and adopts a wet 7-speed dual clutch transmission.
It mainly focuses on high-end, and is a sports compact car, which is positioned between Langyi and Passat.
大众凌渡虽然一直被大家戏称为“宽体奢适轿跑”,不过这台车本身的颜值确实很高, 在整车外形上凌渡还是比较低调不张扬的,两侧扁平不失锐利的大灯被上下两根金属镀铬条连接起来显得很是整齐不过又不失力量感,从前脸看过去,新款凌渡仿佛被加了宽体一般。即使配件不算丰富,不过国内还是有很多玩家都在努力把凌渡改得与众不同。
Although Volkswagen lingdu has always been jokingly called "wide body luxury car running", the car itself is indeed very beautiful, In terms of vehicle shape, lingdu is relatively low-key and unobtrusive. The flat and sharp headlights on both sides are connected by two metal chrome strips, which is very neat but does not lose the sense of strength. From the front face, it seems that the new lingdu has been added with a wide body. Even if the accessories are not rich, there are still many players in China who are trying to make lingdu different.
AIRBFT专用气囊:
Airbft special airbag:
