查看: 767|回复: 0
“犀利型男” 雷克萨斯RC-F改装完美空气避震打造速度与激情
发表于 2020-12-10 13:37:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Sharp man" Lexus rc-f refitting perfect air shock absorbers to create speed and passion
2013年年中,经过蜕变的新一代雷克萨斯RC-F ,特别是F Sport版本就曾以它夸张犀利的外形结结实实的惊艳了一把。而今年日内瓦车展上,雷克萨斯发布的另一款全新轿跑RC- F  再一次吸引了所有人的目光,原因很简单,它实在是太犀利,太有型了。
In the middle of 2013, the new generation of Lexus rc-f, especially the f sport version, was astonished by its exaggerated and sharp appearance. At this year's Geneva Motor Show, Lexus released another new car run rc-f, which attracted everyone's attention again. The reason is very simple. It's really sharp and stylish.
犀利哥雷克萨斯RC改装了全世界最知名的AIRBFT空气避震,这款避震套件是台湾SF绞牙避震搭配AirBft气囊升级的专用版空气避震器,本款控制系统带有三段记忆功能,遥控调节车身升降,四轮独立。
Sharp brother Lexus RC has refitted the world's most famous airbft air shock absorber. This kind of shock absorber is a special version of Taiwan SF twisted teeth shock absorber with airbft air bag upgrade. This control system has three memory functions, remote adjustment of body lifting and four wheels independent.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
