查看: 662|回复: 0
一起耀出锋芒--福特野马气动避震低姿态改装优雅不失狂野
发表于 2020-12-9 15:47:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford Mustang's aerodynamic shock absorber
福特野马是在美国土生土长的"肌肉"跑车,第六代车型自2013年诞生以来,凭借着霸气的 外观 、不俗的 动力 表现以及较为"亲民"的售价迅速风靡全球,让其成为了销量最好的双门跑车之一。在国内也受到了不少车迷的青睐,尤其是2.3T的野马。不过只有310多马力的它,常常被部分网友调侃不是纯正的野马!今天我们来看看改装气动避震低姿态的福特野马的魅力!
Ford Mustang is a "muscle" sports car that was born and bred in the United States. Since its birth in 2013, the sixth generation model has become one of the best-selling two door sports cars with its aggressive appearance, excellent power performance and relatively "people-friendly" price. It is also favored by many fans in China, especially the 2.3t Mustang. However, it has only 310 horsepower, which is often ridiculed by some netizens. It is not a pure wild horse! Today, let's take a look at the charm of the Ford Mustang which is refitted with aerodynamic shock absorbers!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
