查看: 574|回复: 0
奔驰GLC改装气动避震悬挂低趴魅力
发表于 2020-12-9 15:04:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奔驰GLC改装气动避震悬挂低趴魅力
奔驰GLC是奔驰推出的首款全新跨界车型,2015款发布。奔驰GLC实质上可以看做是GLK的轿跑版,而之所以奔驰GLC要到2016年才会问世,奔驰正在计划主要依靠其SUV与跨界车,推出的首款全新跨界车型是2015款奔驰GLC。
Mercedes Benz GLC is the first new crossover model launched by Mercedes Benz, with 2015 model released. In essence, Mercedes Benz GLC can be regarded as a car running version of GLK. The reason why Benz GLC will not come out until 2016 is that Mercedes Benz is planning to rely mainly on its SUVs and crossover vehicles. The first brand-new crossover model launched is 2015 Benz GLC.
多数人使用气压式避震器最主要的目的并非以舒适性为主,随时调整车身底盘的高低才是换装气压式避震器最主要的诉求。气压避震是用气囊来替代弹簧的减震作用,然后在使用控制系统给气囊充气,充气量愈多车身就上升愈高,反之则会让车身降低,所以气压避震主要的目的是控制高低,而避震功能还是以原本的弹簧、减震筒为主。The main purpose of most people using pneumatic shock absorbers is not comfort, but to adjust the height of body chassis at any time is the most important demand to replace pneumatic shock absorbers. Pneumatic shock absorber uses air bag to replace the shock absorption effect of spring, and then uses the control system to inflate the air bag. The more air is inflated, the higher the body will rise. Otherwise, the body will be lowered. Therefore, the main purpose of pneumatic shock absorber is to control the height, and the shock absorption function is mainly based on the original spring and shock absorber.
Let's talk about the pneumatic shock absorber control system. The mainstream control systems are generally divided into two types: those with memory mode and those without memory mode. Those with memory mode have to mention the control system of airbft in the United States. It should be the first system to enter China. Its stability and convenience of use are trusted and liked by many riders! Let's talk about its function and intelligence!
公司名称:上海淞江减震器集团有限公司  英文名称:AIRBFT
