查看: 590|回复: 0
“ 见颜 见智 ”奥迪A5AIRBFT气动避震低姿态风格改装施工
发表于 2020-12-9 14:39:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modification construction of Audi a5airbft pneumatic shock absorber with low attitude style
奥迪A5,于2007年3月6日在欧洲接受预订,第一批成品预计6月交付用户使用,是奥迪家族中的一个全新系列,定位于高档双门轿跑车这一充满激情的细分市场  。
奥迪A5将奥迪一惯推崇的充满动感的设计、激动人心的动力与操控性能、卓越的制造工艺完美结合,是奥迪“突破科技,启迪未来”品牌理念的全新诠释。在奥迪A5身上,可以看到很多2003款奥迪Nuvolari quattro概念车的设计元素(Nuvolari quattro概念车其名字源于奥迪赛车史上最伟大的车手之一,Tagio Nuvolari,他在30年代驾驶四环银箭赛车多次获得欧洲GP大奖赛冠军),让人们首次感受到奥迪对强劲动力、专业化设计、高性能潜力跑车的追求——向未来迈进了大胆的一步。
Audi A5, which was ordered in Europe on March 6, 2007, and the first batch of finished products are expected to be delivered to users in June. It is a brand new series of Audi family, positioned in the passionate market segment of high-end coupe.
Audi A5 perfectly combines dynamic design, exciting power and handling performance, and excellent manufacturing process, which is a new interpretation of Audi's brand concept of "breaking through technology and enlightening the future". In Audi A5, you can see many design elements of the 2003 Audi nuvolari Quattro concept car (the name comes from tagio, one of the greatest drivers in the history of Audi racing) Nuvolari, who won the European GP Grand Prix for many times in the 1930's, let people feel Audi's pursuit of strong power, professional design and high performance potential sports cars - a bold step forward to the future.
大家都知道非常低的底盘一直都是那些超级跑车的专属!但是下面的这台改装气动避震的奥迪A5就不一样了,通过改装来实现了低趴的姿态,比起超跑也是有过之而无不及,实用性也是非常强大,降到最低的时候底盘高度可以比超跑还要低,升高之后可以达到原车的高度,甚至可以比原车还要高,通过性完全是没有问题的!因为出色的视觉效果和实用性,气动避震改装成为了当下主流的改装方式!
We all know that the very low chassis has always been the exclusive property of those super sports cars! However, the Audi A5 refitted with pneumatic shock absorbers is not the same. It achieves a low prone posture by refitting. Compared with super running, it is also more practical. When it is reduced to the lowest level, the chassis height can be lower than that of the super run. After raising it, it can reach the height of the original car, even higher than that of the original car. There is no problem with the trafficability Yes! Because of its excellent visual effect and practicability, pneumatic shock absorber refitting has become the mainstream modification method!
『气动减震器,能够轻易改变车身高度』李洋
