查看: 734|回复: 0
本田缤智改装低趴案例 AIRBFT空气避震的姿态魅力
发表于 2020-12-8 14:33:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Honda Binzhi modified low lying case AIRBFT air shock attitude charm
相信大家对本田缤智已经相当熟悉,连同它的同胞兄弟XRV在小型SUV市场创出了一片天,在路上能见度十分高。但是将它改成低趴的样子,那就很少见了,接下来就给大家介绍一下这辆与众不同的缤智。
I believe that everyone is quite familiar with Mota Binzhi. Together with its brother xrv, it has created a big space in the small SUV market, and its visibility is very high on the road. However, it is very rare to change it into a low prone appearance. Next, we will introduce this unique Pinzhi.
说到改装的,缤智则可能不是热门的车型。它以实用为主,玩心重的年轻人大多可能会选择飞度 。不过这辆缤智的主人却可以说在本地为缤智改装开了个头。
When it comes to refitting, Binzhi may not be a popular model. It is mainly practical, and young people who play hard are likely to choose fit. However, the owner of the car can be said to have made a start in the local refitting of the car.
低趴范儿”在全球已经成为一种流行趋势,深受广大改装车迷追捧,这种方式的改装在美国日本更是成为一种普遍现象,它不仅能在视觉上给人一种强烈的冲击感,而且也能充分的展现出车主的个性和独特品味。
"Low prone fan Er" has become a popular trend in the world, and is deeply sought after by the majority of refitting fans. This way of refitting has become a common phenomenon in the United States and Japan. It can not only give people a strong visual impact, but also fully show the owner's personality and unique taste.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
It's not easy to choose the right pneumatic shock absorber. The grades of pneumatic shock absorbers are different. There are many different brands.
