查看: 660|回复: 0
“自由本能, 尽情释放”奥迪改装气动避震悬挂 这姿态堪称一流
发表于 2020-12-7 14:42:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Free instinct, let go" Audi refits pneumatic shock suspension, which can be regarded as first-class
奥迪(Audi),德国豪华汽车品牌,其标志为四个圆环相扣。现为德国大众汽车公司的子公司,总部设在德国的英戈尔施塔特,并在中国等许多国家有分公司。
2018年12月20日,2018世界品牌500强排行榜发布,奥迪位列51位。  2019年10月,Interbrand发布的全球品牌百强榜排名42。
Audi, a German luxury car brand, is marked by four rings. It is a subsidiary of German Volkswagen, headquartered in Ingolstadt, Germany, and has branches in China and many other countries.
On December 20, 2018, the list of the world's top 500 brands was released, and Audi ranked 51st. In October 2019, Interbrand ranked 42 in the global top 100 brand list.
气动避震改装的低姿态,也是近几年在国内非常流行的一种改装方式,所谓“百改降为先 是为什么呢?
一台车的气质与否,完全取决于车身姿态,降低车身的方法有很多种,为什么大多数玩家会选择气动避震呢?
因为气动避震的特长是能屈能伸,车主可以随时调节车身底盘的高度。
高速行驶时可以降低车身来降低重心增加稳定性和降低风阻,路况不好的话可以及时的升高底盘来增强通过性,另外一个很显著的特点就是视觉效果非常的突出,是一款兼顾实用性和视觉享受的个性改装!
The low attitude of pneumatic shock absorber refitting is also a very popular modification method in China in recent years?
The temperament of a car depends entirely on the body posture. There are many ways to lower the body. Why do most players choose pneumatic shock absorbers?
Because pneumatic shock absorber is flexible, the car owner can adjust the height of the body chassis at any time.
When driving at high speed, the body can be lowered to reduce the center of gravity, increase stability and reduce wind resistance. If the road condition is not good, the chassis can be raised in time to enhance the trafficability. Another significant feature is that the visual effect is very prominent. It is a personalized refit that takes into account the practicability and visual enjoyment!
