查看: 614|回复: 0
野马气动避震姿态诱惑展现
发表于 2020-12-6 14:36:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
野马气动避震姿态诱惑展现
Wild horse's aerodynamic shock absorption posture temptation show
In 1962, Ford developed Mustang's first concept car, Mustang I. It's a two seater sports car with a central engine. The name of Mustang is to commemorate the legendary P-51 Mustang fighter in World War II.
总是发“趴”在地上的车好多人不理解疑问也多,就通俗易懂的解释一下,气动,通过改装四支“空气避震+控制器”从而达到在车内随意调节车身高度的目的。很多品牌高端配置车型也会有,它叫做“底盘升降”差别在哪?升的没我们高,降的没我们低,升降速度没我们快。 今天分享一款酷炫的福特野马改装的气动避震!
A lot of people don't understand and have a lot of questions about the car that is always lying on the ground. It is easy to explain that pneumatic, by refitting four "air shock absorbers + controllers", can achieve the purpose of adjusting the height of the body in the car at will. Many brands have high-end configuration models, which are called "chassis lifting". What is the difference? The rising is not as high as ours, the descending is not as low as ours, and the ascending and descending speed is not as fast as ours. Today share a cool Ford Mustang modified pneumatic shock absorber!
Let's talk about the pneumatic shock absorber control system. The mainstream control systems are generally divided into two types: those with memory mode and those without memory mode. Those with memory mode have to mention the control system of airbft in the United States. It should be the first system to enter China. Its stability and convenience of use are trusted and liked by many riders! Let's talk about its function and intelligence!
