查看: 579|回复: 0
"改变 让旅程不同”奔驰C级旅行气动避震改装姿态魅力完美提升
发表于 2020-12-6 13:30:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Change makes the journey different" Mercedes Benz C-class travel aerodynamic shock absorber modification posture charm improved perfectly
奔驰C级旅行轿车是奔驰旗下的一款旅行轿车,采用奔驰品牌最新的家族式风格,且车身尺寸相比老款车型全面提升。
Benz C-class touring car is one of Mercedes Benz's travel cars. It adopts the latest family style of Benz brand, and its body size is comprehensively improved compared with the old model.
现在大多数车主,买车的时候除了喜欢看外观、内饰、配置、动力和口碑等等之外,也会考虑该车有没有改装的潜力。随着汽车个性化、舒适性的需求逐渐提高,汽车已不再是简单的交通工具,而是一个能够为人们带来乐趣舒适的玩伴。改装气动避震低姿态对很多年轻的车友来说,完美的姿态有很大的吸引力,一起来欣赏奔驰C级的魅力低姿态风格!
At present, most car owners, in addition to looking at the appearance, interior, configuration, power and reputation, will also consider whether the car has the potential to be modified. With the increasing demand for personalized and comfortable cars, the car is no longer a simple means of transportation, but a playmate who can bring fun and comfort to people. For many young riders, the perfect posture has great attraction. Let's enjoy the charm of Mercedes Benz C-class with low attitude!
