查看: 709|回复: 0
G70玩起AIRBFT气动避震改装也是风情万种
发表于 2020-12-6 11:59:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
G70 plays airbft pneumatic shock absorber refitting is also a variety of styles
气动避震改装是目前世界上一种潮流的低趴改装风格,主要针对的是有个性有追求的年轻人,对车子有一种狂热的爱好,改装是一种对车子不满意地方的修改,改到让自己满意为止。气动避震的改装就是一群恐高症患者的福音,超低的姿态,完美的车型形态,总是让人热血澎湃!
Pneumatic shock absorber refitting is one of the most popular low lying refitting styles in the world. It is mainly aimed at young people who have personality and pursuit. They have a crazy love for cars. Refitting is a modification of unsatisfied parts of the car until you are satisfied with it. The refitting of pneumatic shock absorbers is the gospel of a group of acrophobia patients. The ultra-low posture and perfect vehicle shape always make people excited!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
