查看: 659|回复: 0
玛莎拉蒂吉博力AIRBFT气动避震套件随时随地调整车身高度手机遥控器控制方便简单
发表于 2020-12-5 14:58:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Maserati jibuli airbft pneumatic shock absorber can adjust body height anytime and anywhere, and the remote control of mobile phone is convenient and simple
Let's talk about the pneumatic shock absorber control system. The mainstream control systems are generally divided into two types: those with memory mode and those without memory mode. Those with memory mode have to mention the control system of airbft in the United States. It should be the first system to enter China. Its stability and convenience of use are trusted and liked by many riders! Let's talk about its function and intelligence!
Three segment memory function: the car owner can set three different height modes: high position, normal position and low position by pressing the key 1, 2, 3 One button up or down to the height suitable for the current road conditions, high speed can be reduced to the first gear, low driving, reduce the center of gravity to enhance the stability of the car and reduce the wind resistance, but also to a certain extent save fuel. The city or the countryside can rise to the second gear normal height to drive, can deal with most of the road conditions, if encounter very bad road conditions, you can raise the car to 3 From the lowest to the lowest gear, it's about the highest! Three gears of different heights can be quickly switched at any time!
