查看: 602|回复: 0
福特野马改装AIRBFT气动避震悬挂 低姿态风格
发表于 2020-12-5 14:40:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford Mustang modified airbft pneumatic shock suspension low attitude style
Super Snake是福特在13年底特律展出的野马Shelby GT500系列里的新车型。这次底特律车展中所展出的Super Snake则更是将Shelby GT500性能推进至顶端的版本。 这部Super Snake是由1960年代创造出AC Shelby Cobra等经典传说跑车的Carroll Shelby率领自己所创立的Shelby American公司开发团队所共同开发完成的。一代赛车传奇人物Carroll Shelby于2012年5月时不幸过世,这部Super Snake也就成为他最后、最强的野马遗作。
In 1962, Ford developed Mustang's first concept car, Mustang I. It's a two seater sports car with a central engine. The name of Mustang is to commemorate the legendary P-51 Mustang fighter in World War II.
Super snake is a new model of the Mustang Shelby GT500 series that Ford exhibited in Detroit in 2013. The super snake on display at the Detroit auto show is a version that pushes Shelby GT500 performance to the top. This super snake was jointly developed by the Shelby American development team led by Carroll Shelby, who created classic legendary sports cars such as AC Shelby Cobra in the 1960s. A generation of racing legend Carroll Shelby died in May 2012, and this super snake became his last and strongest Mustang legacy.
总是发“趴”在地上的车好多人不理解疑问也多,就通俗易懂的解释一下,气动,通过改装四支“空气避震+控制器”从而达到在车内随意调节车身高度的目的。很多品牌高端配置车型也会有,它叫做“底盘升降”差别在哪?升的没我们高,降的没我们低,升降速度没我们快。 今天分享一款酷炫的福特野马改装的气动避震!
A lot of people don't understand and have a lot of questions about the car that is always lying on the ground. It is easy to explain that pneumatic, by refitting four "air shock absorbers + controllers", can achieve the purpose of adjusting the height of the body in the car at will. Many brands have high-end configuration models, which are called "chassis lifting". What is the difference? The rising is not as high as ours, the descending is not as low as ours, and the ascending and descending speed is not as fast as ours. Today share a cool Ford Mustang modified pneumatic shock absorber!
改装界流行一句话叫"百改降为先“我再补充一句,低趴才是王道!任何的改装如果没有气动避震改装的话,我感觉就像行尸走肉,徒有一个光鲜的外表,没有灵魂!正所谓一低遮百丑,气动避震改装是提升整车气质最关键的一笔
There is a popular saying in the field of refitting that "100 changes should be reduced to the first". I will add that low lying is the king's way! If there is no pneumatic shock absorber refitting, I feel like a walking corpse, with a bright appearance and no soul! As the so-called low cover hundred ugliness, pneumatic shock absorber refitting is the most important thing to improve the quality of the vehicle
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
容易导致慢性漏气,引起气压不稳定,气罐内的温度会升高,气动调节就会失去精准度
It is easy to cause chronic air leakage and unstable air pressure. The temperature in the air tank will rise and the accuracy of pneumatic regulation will be lost
